Results 1 to 5 of 5
    Junior Member level 2
    Points: 1,411, Level: 8
    Sep 2012
    India
    20
    1,411
    8
    PN and jitter for low frequency oscillators
    I wanted to measure jitter (by simulation) for my 10KHz oscillator. Can I run a PN analysis using spectre and integrate it to find jitter?
    Why there are no Phase noise plots for low frequency oscillators and how are their jitter characterised in general?
    Points: 30,757, Level: 42
    BigBoss's Avatar
    Nov 2001
    Turkey
    4,512
    30,757
    42
    Re: PN and jitter for low frequency oscillators
    You can do PSS+PNOISE Analysis but the accuracy won't be so good.Because the most difficult part of a modelization is to predict Low Frequency Noise components.
    Sep 2012
    India
    20
    1,411
    8
    Quote Originally Posted by BigBoss View Post
    Hi, thanks for the reply. Can you elaborate on this, as to why the accuracy will not be good?
    BigBoss's Avatar
    Nov 2001
    Turkey
    4,512
    30,757
    42
    Quote Originally Posted by vinogunasekaran View Post
    The answer was there..
    When you simulate any kind of circuit in fact you're using a special calculator. nothing more ..And every element has been characterized/modeled by some mathematical expressions and this calculator uses those expressions.If these math. equations are not sufficiently correct, the result will also have some error margins ( in a acceptable rate or more ).
    One of the most difficult portion of modeling engineering is to model Low Frequency Noise task.For instance 1/f Noise Model for GaAs or III/IV Compound Semiconductor Devices is not accurate at all due to this difficulty..Therefore analysis for Low Frequency Noise will not be very accurate , maybe an approximate value..
    Sep 2012
    India
    20
    1,411
    8
    okay. Got it.
