Results 1 to 4 of 4
    Full Member level 4
    Points: 1,327, Level: 8
    Jan 2018
    220
    1,327
    8
    Reflections when conjugately matched
    Hi, as per Pozar's Microwave Engineering book, there is a condition
    "A special case of the transducer power gain occurs when both the input and output are matched for zero reflection (in contrast to conjugate matching). Then GammaL = GammaS = 0" then GT=S21^2.
    And another one is conjugate matched condition.
    Does this mean ever after performing conjugate matching, there will be still reflections?. Could someone explain the difference between these two conditions.
    Thanks in advance.
    Points: 17,282, Level: 31
    pancho_hideboo's Avatar
    Oct 2006
    Real Homeless
    2,665
    17,282
    31
    Re: Reflections when conjugately matched
    Quote Originally Posted by circuitslave View Post
    Voltage wave is reflected.
    Surely read and learn Power wave in Pozar’s Book, before EDA Tool Play.
    See the followings.
    https://www.edaboard.com/showthread.php?378353#5
    https://www.edaboard.com/showthread.php?378353#20
    Points: 20,761, Level: 35
    Jan 2011
    3,389
    20,761
    35
    Quote Originally Posted by circuitking View Post
    Thanks in advance.
    There's a subtle distinction between travelling waves (aka voltage waves) and power waves. For travelling waves, the reflection coefficient is defined as Gamma=(ZL-Zs)/(ZL+Zs). For power waves, Gamma=(ZL-Zs*)/(ZL+Zs). So for a conjugate match, the power wave reflection coefficient will be zero, but the travelling wave reflection might not be.
    Points: 30,637, Level: 42
    BigBoss's Avatar
    Nov 2001
    Turkey
    4,492
    30,637
    42
    Researched in my literature and found very intuitive explanation about Power Waves and Scattering
    "Microwave Transistor Amplifiers-Analysis and Design"-Guillermo Gonzalez Section 1.7 pp:45-60
