Results 1 to 15 of 15
    Newbie level 5
    Points: 60, Level: 1
    Nov 2019
    10
    60
    External C++ compilation and DPI question
    Hi -
    I'm having trouble creating a .dll file by using the gcc command on windows (MinGW). Here is the command I'm running:
    command: gcc -shared -Bsymbolic -o mytest.dll mytest.cpp
    error:: c:/mingw/bin/../lib/gcc/mingw32/8.2.0/../../../../mingw32/bin/ld.exe: C:\Users\aashoka\AppData\Local\Temp\cc2UzHHe.o:myt est.cpp:(.text+0x3a): undefined reference to `Write' collect2.exe: error: ld returned 1 exit status
    The .h file --- created using the command: vlog -sv ./mytb.sv -dpiheader ../src_cpp/experiment1.h -- is included in the mytest.cpp. And this file contains the Read and Write functions that is implemented in the mytb.sv. I also have the following lines in mytb.sv
    export "DPI-C" task Write;
    export "DPI-C" task Read;
    import "DPI-C" context task mymain();
    Any thoughts on how I can get past the dll creation step?
    The files I'm using are attached.
    Thanks,
    Aditya
    Advanced Member level 1
    Points: 5,642, Level: 17
    May 2005
    460
    5,642
    17
    Re: External C++ compilation and DPI question
    Can you paste the definition of Write from experiment1.h
    Advanced Member level 3
    Points: 6,551, Level: 19
    Created Blog entry 7 years registered
    Dec 2011
    Fremont, CA, USA
    794
    6,551
    19
    Blog Entries
    If you are using a version of Questa/Modelsim within the last 8 years, you can put the C/C++ file on the vlog command line and skip the separate gcc step.
    Dave Rich
    Senior Verification Consultant
    Mentor Graphics Corporation
    Newbie level 5
    Nov 2019
    10
    60
    Here is the whole file:
    Code C - [expand]
    8
    9
    10
    11
    12
    13
    14
    15
    16
    17
    18
    19
    20
    21
    22
    23
    24
    25
    26
    #Experiment
    #ifndef INCLUDED_EXPERIMENT1
    #define INCLUDED_EXPERIMENT1
    #ifdef __cplusplus
    #define DPI_LINK_DECL extern "C"
    #else
    #endif
    #include "svdpi.h"
    DPI_LINK_DECL DPI_DLLESPEC
    int
    mymain();
    DPI_LINK_DECL int
    Read(int addr,int* read_data);
    DPI_LINK_DECL int
    Write(int addr,int data);
    #endif
    Newbie level 5
    Nov 2019
    10
    60
    @dave_59: Things work fine when I put c/c++ file in the command line. I want to get this working with the external GCC step.
    Dec 2011
    Fremont, CA, USA
    794
    6,551
    19
    Blog Entries
    Quote Originally Posted by ghertz View Post
    Why do you have that requirement?
    Dave Rich
  7. #7
    Newbie level 5
    Nov 2019
    10
    60
    Quote Originally Posted by dave_59 View Post
    Huge code base. I don't think it makes to create a new work flow. It'd be nice to keep HW and software different. ModelSim User's Manual talks about using vlog to compile (default autocompile flow), and external compilation flow (gcc -> object file -> and link that file in modelsim). It looks like I'm following all the instructions. Can't seem to understand why things aren't working.....
  8. #8
    Dec 2011
    Fremont, CA, USA
    794
    6,551
    19
    Blog Entries
    Try
    g++ -c -I<install_dir>\questasim\include mytest.cpp
    g++ -shared -Bsymbolic -o mytest.dll mytest.o -L<install_dir>\questasim\win32
    Dave Rich
  9. #9
    Newbie level 5
    Nov 2019
    10
    60
    Try
    Doesn't work. I still get an error when I try to create the .dll file
    These are the commands I tried:
    [1] g++ -c -IC:\intelFPGA\17.0\modelsim_ase\include -o ./mytest.o ./mytest.cpp
    comments: I was able to execute this command without any issues
    [2] g++ -shared -Bsymbolic -o ./mytest.dll ./mytest.o -LC:\intelFPGA\17.0\modelsim_ase\win32aloem
    comments: I wasn't able to get past this step
    error message: c:/mingw/bin/../lib/gcc/mingw32/8.2.0/../../../../mingw32/bin/ld.exe: ./mytest.o:mytest.cpp:(.text+0x2d): undefined reference to '`PrintHelloWorld'
    collect2.exe:error:ld returned 1 exit status
    # file: mytest.cpp
    #include<stdio.h>
    #include "experiment3.h"
    int mymain() {
       printf("---starting test in c-domain---\n");
       PrintHelloWorld();
       return 0;
    # file: experiment3.h
    #ifndef INCLUDED_EXPERIMENT3
    #define INCLUDED_EXPERIMENT3
    #ifdef __cplusplus
    #else
    #endif
    #include "svdpi.h"
    int
    mymain();
    DPI_LINK_DECL void
    PrintHelloWorld();
    #endif
    # file: mytb.sv
    module mytb;
       timeunit 1ns/1ps;
       export "DPI-C" function PrintHelloWorld;
       .<some stuff>
       .<some stuff>
       .<some stuff>
       .<some stuff>
       function void PrintHelloWorld();
          $display("HelloWorld\n");
       endfunction
    //start test
    initial begin
       repeat(10)@(posedge clk_reg);
       mymain();
    end
    endmodule
  10. #10
    Points: 12,779, Level: 27
    Apr 2010
    1,938
    12,779
    27
    Which object container has PrintHelloWorld() ?
  11. #11
    Newbie level 5
    Nov 2019
    10
    60
    Quote Originally Posted by srizbf View Post
    PrintHelloWorld() is part of the SystemVerilog Testbench. GCC only knows about PrintHelloWorld() through the experiment3.h header file (the one generated by ModelSim)
  12. #12
    Points: 263,357, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    46,008
    263,357
    100
    The common point of all failing tests is that the functions exported from SV are not visible in the C name space. I'm not familiar with the DPI stuff, the examples I see at the web are looking slightly different, e.g. marking the SV symbols imported to C as extern. Seriously I don't even understand which file imports the SV originated symbols to the linker.
  13. #13
    Newbie level 5
    Nov 2019
    10
    60
    You are right. The functions exported from SV is not visible to the C namespace. The experiment3.h header file does have the extern keyword. Can you elaborate on "Seriously I don't even understand which file imports the SV originated symbols to the linker" ?
  14. #14
    Apr 2010
    1,938
    12,779
    27
    If it is not able to find the function at link time it gives the error message.
  15. #15
    Newbie level 5
    Nov 2019
    10
    60
    I still haven't gotten this to work....
