Results 1 to 3 of 3
    Points: 428, Level: 4
    Feb 2019
    49
    428
    How I can make use of the resources of only certain regions of the device in Vivado?
    Greetings ... tell you that a few days ago I translated a single verilog file to vhdl to add it to my vhdl project in Vivado 2017.3 which has the function of controlling the transmission and reception of data for a hotlink interface, apparently no problem in simulation , synthesis and implementation through a tcl scritp, but when testing it in the hardware I observe that the transmission speed dramatically reduces. I was suggested to analyze the design of the project implemented in the device and in this way verify that the design had changed with respect to a version that still used the verilog file, as shown in the attached image.
    The truth is that I am new to the area of implementation and would like to know how I can make use of the resources of only certain regions of the device?
    Points: 31,949, Level: 43
    ads-ee's Avatar
    Sep 2013
    USA
    7,393
    31,949
    43
    Re: How I can make use of the resources of only certain regions of the device in Viva
    You can use pblocks. As a starter you can read over this document. Search for pblock to get some information on it, then you can look for it in some of the other documentation.
    You might want to try searching for pblock using the Xilinx Document Navigator.
    Points: 38,138, Level: 47
    Jun 2010
    6,907
    38,138
    47
    What is your goal?
    It is normal that a implemented design changes between builds because placement relies on a random seed. If the source code, constraints or seed change, then the final result will be different to a previous build.
    Are you assuming that because the implementation has changed your design no longer works? If your design uses fully synchronous design and is properly constrained, if the design meets timing then it should work every time. If it is not working, I suggest there is a problem with the code or lack of timing specs. Using pblocks may help only by masking the problem in specs or source code.
    So, what exactly is the problem (pblocks are not usually the answer to anything).
