Output Impedance Of a Triple cascode
circuitking
Full Member level 5
Hi, What is the output impedance seen at the drain of the third transistor in the below figure.
Should Rout3 > Rout2 ? at DC and at higher frequencies, for example 50GHz
Thanks in advance
Even a simple model of "real Zout" at 50 GHz has to consider at least all transistor capacitances.
The problem I have is that when I have just a cascode connection, the circuit is stable but when I connect 3 or 4 transistors in the stack it is not stable anymore. The reason I see is the real part of output impedance of the stack is negative.
real(Zout3) is not equal to Rout3.
Can you surely understand Rout2 ?
Yeah now I see. In gain formula gm*r0 (at DC), the r0 is Rout3 and not real(Zout3).
Yes, you can see it, if you calculate the impedance with sufficient complex model.
Negative real part is due to Y12.
You don’t care about feedback path of each MOSFET at all.
Surely learn very basic things before EDA Tool Play which you like.
