how to select ac to dc adapter for a given device
ravi.2k17
hi,
I have an electronics devices with required input dc rating 24v -- 1 amp
however a got a ac to dc adapter with output dc rating 12v -- 2 amp will this adopter work for my device ? do we need to see wattage (V * I) of a device while deciding its compatible adopter? can i use any adapter as long as its output watts are same as input dc watts of my device ? eg what about 6V -- 4Amp ???
thanks
If your application needs 24V then your adapter needs to ouput 24V.
--> adapter voltage rating needs to be 24V +/- some tolerance. (no 12V no 6V no other voltage)
If your application draws 1A then your adapter needs to be able to deliver 1A. It is no probem if it can deliver more than 1A.
--> adapter current rating needs to be 1A or higher
The voltage must match.
The current rating of the adapter must be equal to or greater than the device. More means you have a safety margin.
If the voltage and current ratings are sufficient, the power rating will also be sufficient but you can't exchange voltage for current or the opposite.
if current output is more than the required in adopter, will it not be risk of electronic device of burning? due to over load?
Hi
Ravi
You cant match the power by multiplying VxI. Current and voltage should match (Using slightly higher voltage or current device is the best practice)
Hi
Ravi
Suppose your equipment rated for 10VA, 10V and 1 A then your device never take more than 1 A if it is in a good condition. If any short circuit in your equipment should take care of your equipment input fuse mechanism.
