Results 1 to 17 of 17
    Full Member level 4
    Points: 1,318, Level: 8
    Jan 2018
    219
    1,318
    8
    What is the cutoff frequency of the capacitively loaded Transmission line
    Hi, I connected a circuit like shown below. Let mtlines have length l, per unit inductance Ltl and capacitance Ctl, and capacitance C, what should be the formula for cutoff frequency?
    In various books it is given that the cutoff frequency should be fc=1/(pi*sqrt(Ltl(Ctl+C/l))) but I don't see the same when I simulated. Thanks in advance.
    Points: 17,267, Level: 31
    pancho_hideboo's Avatar
    Oct 2006
    Real Homeless
    2,662
    17,267
    31
    Re: What is the cutoff frequency of the capacitively loaded Transmission line
    Quote Originally Posted by circuitslave View Post
    Generally wrong, although I don't know what book you read.
    Your circuit is well-known capacitive discontinuity in uniform line.
    What value do you set for reference impedance of ports ?
    Full Member level 4
    Jan 2018
    219
    1,318
    8
    Quote Originally Posted by pancho_hideboo View Post
    50 ohm in both ports
    Points: 6,871, Level: 19
    Jun 2012
    Edmonton, Canada
    1,057
    6,871
    19
    Quote Originally Posted by circuitking View Post
    That's probably for an infinite cascade of embedded capacitors. I'm not sure how well one capacitor would reproduce this result. I would recommend to try additional periods and see of anything changes.
    Oct 2006
    Real Homeless
    2,662
    17,267
    31
    So large mismatch at port, although I don't know what you set for "mtline".
    What quantity do you see in simulation ?
    Points: 261,166, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,618
    261,166
    100
    If mtline is setup as an ideal 50 ohm transmission line, the answer is very simple and you should be able to derive it yourself. Just a first order low pass with tau = c*Z0/2.
  7. #7
    Full Member level 4
    Jan 2018
    219
    1,318
    8
    I used an RLGC file and the Z0 for line is more than 50 ohm
  8. #8
    Oct 2006
    Real Homeless
    2,662
    17,267
    31
  9. #9
    Full Member level 4
    Jan 2018
    219
    1,318
    8
    I see cutoff Frequency of 119.43 GHz in simulation
  10. #10
    Oct 2006
    Real Homeless
    2,662
    17,267
    31
    No.
    What quantity do you see to evaluate cutoff Frequency in your EDA Tool Play ?
  11. #11
    Full Member level 4
    Jan 2018
    219
    1,318
    8
    No.
    I check S21.
  12. #12
    Oct 2006
    Real Homeless
    2,662
    17,267
    31
    I check S21.
    You must not use S-parameter, since you can not understand RF and very basic things at all.
    https://www.edaboard.com/showthread.php?385709#2
    https://www.edaboard.com/showthread.php?385709#7
  13. #13
    Full Member level 4
    Jan 2018
    219
    1,318
    8
    What happens if the Line is not 50 ohm. is the same equation applicable?
  14. #14
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,618
    261,166
    100
    Surely not.You get reflections at the ports, the line length also matters, and the frequency characteristic is no longer monotone. Theres's no simple cutoff frequency formula applicable.
  15. #15
    Full Member level 4
    Jan 2018
    219
    1,318
    8
    Then when to use this formula fc=1/(pi*sqrt(Ltl(Ctl+C/l)))? which scenarios, line with infinite length ?
    If the port impedances are 50 ohm (i.e, in matched condition) voltage gain is equal to power gain (S21). When the circuit is Linear, Pout(dBm)= S21(dB)+Pin(dBm). So it doesn't matter which one I am looking at, all should give same cut off frequency.
  16. #16
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,618
    261,166
    100
    An example of Zline > Zport is shown below. How do you design cut-off frequency in this case?
  17. #17
    Full Member level 4
    Jan 2018
    219
    1,318
    8
    I would consider the -3 dB point as the cutoff frequency. And as you mentioned there is no simple equation to calculate it.
