Results 1 to 6 of 6
    Newbie level 6
    Points: 92, Level: 1
    Oct 2019
    Columbus, Ohio, USA
    12
    92
    Need help to add GaN Transistor on OrCAD
    Hello Everyone,
    I have to simulate a power amplifier using a GaN transistor. So I am using OrCAD as environment simulation, but I cannot find any library that there is this type of transistor. Does anybody have a suggestion of simulator that I can add GaN transistors?
    Many thanks in advance.
    Advanced Member level 3
    Points: 6,155, Level: 18
    Feb 2014
    887
    6,155
    18
    Re: Need help to add GaN Transistor on OrCAD
    Well what GAN fet are you using? The manufactures supply models which should work in most spice tools.
    EPC
    https://epc-co.com/epc/DesignSupport/DeviceModels.aspx
    Gan systems
    https://gansystems.com/gan-transistors/gs66508t/
    Transphorm:
    https://www.transphormusa.com/en/doc.../spice-models/
    Newbie level 6
    Oct 2019
    Columbus, Ohio, USA
    12
    92
    I would like to use the EPC1010. I pretty sure that you showed good options for the spice tools. Thanks much.
    Feb 2014
    887
    6,155
    18
    That's a very old part (by GAN standards). There are at least a couple generations since then. See EPC2012 and EPC2034.
    If you're doing a buck type design use their really good half bridge loss calculator and part selector:
    https://epc-co.com/epc/DesignSupport...onverters.aspx
    Newbie level 6
    Oct 2019
    Columbus, Ohio, USA
    12
    92
    I am designing a power amplifier for a RFID system. It is right, very old. Probably EPC2012 and EPC2034 have similar specification of the EPC1010.
    Points: 20,736, Level: 34
    Jan 2011
    3,388
    20,736
    34
    EPC2010C is the successor to the 1010. Same footprint, same Rds and Vdss. Only major differences are the significantly reduced junction capacitance and thermal impedances.
    EPC2019 and EPC2012C might be worth considering as well.
    I don't know about Orcad, but their models are pretty easy to use in LTspice.
