Results 1 to 5 of 5
    Points: 387, Level: 4
    Feb 2019
    46
    387
    Error: Subprogram <mmcm_count_calc> does not have a body when creating vhdl package.
    Greetings ... comment that I am new creating vhdl packages and a couple of days ago I am trying to create one, but I am having the following error shown in the image.
    Can someone please help me with this error? I leave the code I am using.
    LIBRARY ieee;
      USE ieee.std_logic_1164.all;
      USE ieee.std_logic_unsigned.all;
      USE ieee.std_logic_misc.all;
      USE ieee.numeric_std.all;
    package g1_mmcme2_drp_func_vhdl is
      function mmcm_count_calc (divide : std_logic_vector(7 downto 0) ; phase: std_logic_vector(31 downto 0) ; duty_cycle : integer) return std_logic_vector(37 downto 0);
    end package  g1_mmcme2_drp_func_vhdl;
    package body g1_mmcme2_drp_func_vhdl is
      divide     : in std_logic_vector(7 downto 0); -- Max divide is 128
      phase      : in std_logic_vector(31 downto 0);
      duty_cycle : integer)                         -- Multiplied by 100,000
      return std_logic_vector is
      variable div_calc        : std_logic_vector(13 downto 0);
      variable phase_calc      : std_logic_vector(16 downto 0);
      begin
      div_calc   := mmcm_divider(divide, std_logic_vector(to_unsigned(duty_cycle,32)));
      -- mx[10:9], pm[8:6], dt[5:0]
      phase_calc(10 downto 0) := mmcm_phase(divide, phase);
      -- Return value is the upper and lower address of counter
      --    Upper address is:
      --       RESERVED    [31:26]
      --       MX          [25:24]
      --       EDGE        [23]
      --       NOCOUNT     [22]
      --       DELAY_TIME  [21:16]
      --    Lower Address is:
      --       PHASE_MUX   [15:13]
      --       RESERVED    [12]
      --       HIGH_TIME   [11:6]
      --       LOW_TIME    [5:0]
      return
            -- Upper Address
            "000000000000" & phase_calc(10 downto 9) & div_calc(13 downto 12) & phase_calc(5 downto 0) &
            -- Lower Address
            phase_calc(8 downto 6) & '0' & div_calc(11 downto 0);
     end function;
    end g1_mmcme2_drp_func_vhdl;
    Points: 31,824, Level: 43
    ads-ee's Avatar
    Sep 2013
    USA
    7,366
    31,824
    43
    Re: Error: Subprogram <mmcm_count_calc> does not have a body when creating vhdl packa
    The declaration of the function's return type is just the type it doesn't include a range, i.e. "indexed" name is not a type
    Feb 2019
    46
    387
    Thanks for answering ads-ee ... I'm not sure what you mean by "indexed" name is not a type.
    I have made some changes based on the data sheets https://www.xilinx.com/support/docum...-synthesis.pdf on page 207, but I'm still getting the same error. These are the changes in my code.
    LIBRARY ieee;
      type type_mmcm_count_calc is
        record
          divide          : std_logic_vector(7 downto 0);
          phase           : std_logic_vector(31 downto 0);
          duty_cycle      : integer;
      end record;
      function mmcm_count_calc (arguments: type_mmcm_count_calc) return std_logic_vector(37 downto 0);
      arguments     : type_mmcm_count_calc)
      variable mmcm_count_calc : std_logic_vector(37 downto 0);
      begin
      div_calc   := mmcm_divider(arguments.divide, std_logic_vector(to_unsigned(arguments.duty_cycle,32)));
      phase_calc(10 downto 0) := mmcm_phase(arguments.divide, arguments.phase);
      --       RESERVED    [31:26]
      --       MX          [25:24]
      --       EDGE        [23]
      --       NOCOUNT     [22]
      --       RESERVED    [12]
      --       HIGH_TIME   [11:6]
      --       LOW_TIME    [5:0]
      mmcm_count_calc := "000000000000" & phase_calc(10 downto 9) & div_calc(13 downto 12) & phase_calc(5 downto 0) &
              -- Lower Address
      return
      mmcm_count_calc;
            -- Upper Address
    end function;
    Feb 2019
    46
    387
    I just fixed it, I wasn't getting it very much. This is my new code.
    BIBLIOTECA ieee;
    el paquete g1_mmcme2_drp_func_vhdl es
      función mmcm_count_calc (divide: std_logic_vector (7 downto 0); fase: std_logic_vector (31 downto 0); duty_cycle: integer) return std_logic_vector;
    paquete final g1_mmcme2_drp_func_vhdl;
    el cuerpo del paquete g1_mmcme2_drp_func_vhdl es
      dividir: en std_logic_vector (7 downto 0); - La división máxima es 128
      fase: en std_logic_vector (31 downto 0);
      duty_cycle: integer) - Multiplicado por 100,000
      return std_logic_vector es
      variable div_calc: std_logic_vector (13 downto 0);
      variable phase_calc: std_logic_vector (16 downto 0);
      empezar
      div_calc: = mmcm_divider (divide, std_logic_vector (to_unsigned (duty_cycle, 32)));
      - mx [10: 9], pm [8: 6], dt [5: 0]
      phase_calc (10 downto 0): = mmcm_phase (división, fase);
      - El valor de retorno es la dirección superior e inferior del contador
      - La dirección superior es:
      - RESERVADO [31:26]
      - MX [25:24]
      - BORDE [23]
      - CUENTA [22]
      - Dirección inferior es:
      - PHASE_MUX [15:13]
      - RESERVADO [12]
      - HIGH_TIME [11: 6]
      - LOW_TIME [5: 0]
      regreso
            - Dirección superior
            "000000000000" y phase_calc (10 downto 9) y div_calc (13 downto 12) y phase_calc (5 downto 0) &
            phase_calc (8 downto 6) & '0' & div_calc (11 downto 0);
     función final;
    ads-ee's Avatar
    Sep 2013
    USA
    7,366
    31,824
    43
    Quote Originally Posted by Cesar0182 View Post
    That was from the error message in your first post.
    The error is due to the line in post #3.
    which you finally changed to this in post #4.
    where you finally removed the index "(37 downto 0)" from the type "std_logic_vector".
