Results 1 to 3 of 3
    Full Member level 6
    Points: 4,037, Level: 14
    Dec 2006
    Delhi , India
    328
    4,037
    14
    Gprs modem and AT+ HTTP GET REQUEST?
    Hello Friends ,
    I have a query .
    I need to send data from microcontroller to gsm modem which sends data to a web server.
    Now I m sending the following command:
    AT+HTTPPARA="URL","http://xyz.in/abc.php?v1=436&v2=001&v3=031&v4='LOW'&v5='FAIL'&v6='OK'&v7='HIGH'&v8='CLOSE'&v9='BIGT17662'"
    AT+HTTPACTION=0
    I am sending the data to a table in mysql database.
    The problem is when the table is initially empty , The response time from the server is fast.i.e:
    +HTTPACTION: 0,200,210 (response from the server after i send AT+HTTPACTION=0 ) command. ----> response time 1-2 seconds...
    As i send data again and again the response time increases.
    After sending around 50 times of the similar data.
    The response time increases to about 15-16 seconds.
    +HTTPACTION: 0,200,8050 (response from the server after i send AT+HTTPACTION=0 ) command. ----> response time 15-16 seconds...
    I have to continuously keep on sending the data and read the response also from the server
    What can be done so that i can have instant response 2-3 seconds every time.
    1.Can i flush out the server data buffer after sending every command , will it impact the data writing in the table?
    2. If it can be done How do i do it?
    Points: 78,524, Level: 68
    Apr 2014
    15,940
    78,524
    68
    Re: Gprs modem and AT+ HTTP GET REQUEST?
    at first you need to test WHAT is causing this delay.
    Microcontroller? Modem? Access point? Routers? Server?
    Then you need to test WHY this is happening.
    I assume there are software tools that can monitor the complete internet access, but I donīt have experience with this. --> do an internet search.
    Full Member level 6
    Dec 2006
    Delhi , India
    328
    4,037
    14
    Well friends ,
    I had a work around for the issue .
    Earlier I was reading the entire table of the data base , so it was causing the delay as the table was filling up with more and more entries .
    Now i restricted the view to top 20 rows only so eventually the delay in response reduced.
