Page 2 of 2 FirstFirst 1 2
Results 21 to 25 of 25
  1. #21
    Points: 14,336, Level: 28
    Apr 2014
    2,241
    14,336
    28
    Re: Calculate Capacitance Value from Smith Chart
    Quote Originally Posted by BradtheRad View Post
    I think my simulation is hard to argue with too.
    Here is the mistake in interpretation of your voltage divider experiment:
    You expect the output voltage to be half the total voltage, because R and X are equal.
    But that's wrong. The voltage divider gives R divided by total impedance, and that total impedance magnitude is sqrt(R2 + X2) in this case.
  2. #22
    Points: 53,118, Level: 56
    Apr 2011
    Minneapolis, Minnesota, USA
    12,987
    53,118
    56
    Quote Originally Posted by volker@muehlhaus View Post
    And yes, I pointed out that formula entering the picture in my post #17. So let's see if things are clearing up. I compared more variations to see what happens.
    At left, equal voltages appear across the 10pF and 77 ohm. As you state, they are not 1/2 source voltage.
    The other layouts are 2 series capacitors, or 2 series resistors. Voltages are 1/2 source voltage.
Name:	compare series layouts RC CC 10pF  RR 70 ohms.png
    I believe the RC arrangement above yields 3 dB drop at the rolloff frequency. Output is 0.707 x source voltage, whether taken across C or R.
  3. #23
    Points: 11,708, Level: 25
    Aug 2015
    Melbourne
    1,916
    11,708
    25
    at the 3dB freq the volts reduce to 0.707 across the C only ....
  4. #24
    Apr 2014
    2,241
    14,336
    28
    No, Brad ist correct: the magnitude of R and X are equal in his left testcase, and current is equal, so indeed there is 0.7V across each of the components. But these voltages have a 90° phase offset, so that the total voltage magnitude is sqrt (0.7V2 +0.7V2) = 1V
  5. #25
    Aug 2015
    Melbourne
    1,916
    11,708
    25
    apologies - I must be so used to dealing with L & C, certainly the freq most quoted is when R = 1/ ( 2 pi f C ) so the impedances are the same at that freq.
    as the freq goes up the volts decrease across the C - I was stuck on that thought too
