Results 1 to 13 of 13
    Junior Member level 3
    Points: 1,005, Level: 7
    Feb 2015
    29
    1,005
    7
    Using AD831 in parallel
    Hello every one,
    I am software guy. Some how trying to use ad831 as a mixer connecting in parallel as seen on attached file. +5V and -5V are supplied to both of the mixers from the same source. The problem I faced is here. While measuring the supplied -5V at each mixer it shows ~ -1.2V. what could be the problem?
    Points: 80,263, Level: 69
    Apr 2014
    16,287
    80,263
    69
    Re: Using AD831 in parallel
    * bad DVM
    * bad -5V power supply
    * too high current
    Feb 2015
    29
    1,005
    7
    * bad DVM
    * too high current
    Dear Klaus,
    Thank you very much for your help.
    I have been using my digital multimeter(DVM) for some other circuit and working properly. The -5V supply source is also working perfectly while applying for other circuits. As you mentioned, there is high current measured. That could be a problem. how I may resolve that one?
    Thank you once again.
    Apr 2014
    16,287
    80,263
    69
    First you need to determine:
    * How much current can your supply deliver
    * How much current do you expect your circuit to draw
    * Measure how much your circuit really draws
    We don't know how to debug your circuit, because you didn't show.
    Are the ICs socketed? Breadboard, PCB, is something getting hot....do you have coolant spray? Soldering skills...
    Btw: some brand (negative) voltage regulators suffer from not properly starting up when negative voltage is applied.
    In one application we also had +5V and -5V regulators, but the negative did not start up because the positive was faster..causing some positive glitch at the negative VR's output. This was a cheap 7905 .... we solved this problem by using a high quality brand VR.
    Feb 2015
    29
    1,005
    7
    Dear Klaus,
    The -5V voltage regulator I am using is NJM7905A which can supply up to 1A. I expect my circuit to draw around 0.65A approximately. But, what it actually draws is 1.2A. The PCB is getting very hot for which I disn't use coolant spray. I will try to use standard VR as you suggested. would you suggest me one to use?
    If you have any more suggestions depend on the information I am writing now, I would love to say thank you in advance.
    Thank you a lot.
    Apr 2014
    16,287
    80,263
    69
    I doubt the PCB is getting hot. Usually the electronic parts getting hot. .. and only some of them.
    To detect which one is getting hot:
    * power off and let all get down to room temperature
    * use coolant spray in a way that everything gets white / icy surface.
    * then switch power ON and watch the parts which ones first melt the icy surface.
  7. #7
    Feb 2015
    29
    1,005
    7
    Hello every one,
    I have solved the problem mentioned above by using standard voltage regulator.
    I stack again due to some other problems. A local oscillator oscillates 59MHz where as input RF is 60MHz. An output IF is supposed to be 1MHz, I guess. But, it is 60MHz instead. What could be the reason? would you help me in solving this problem?
    Its schematic is attached above in the beginning.
    Thank you a lot .
  8. #8
    Points: 263,501, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    46,040
    263,501
    100
    For correct double balanced mixer operation (e.g. achieving the specified LO to IF isolation), RF and LO inputs must be DC free. According to your schmematic, this is at least not the case for LO.
  9. #9
    Feb 2015
    29
    1,005
    7
    FvM,
    Thank you a lot for your help.
    I am sorry, i couldn't get your explanation fully(take in to consideration that I am just a beginner to circuit design). As to my understanding, there is no any DC supply to these RF and LO inputs. how could that happen? would you brief it more?
  10. #10
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    46,040
    263,501
    100
    Crystal oscillator output has DC bias of Vcc/2, RF in bias is unknown. Where is it connected to?
    Use capacitor to clock oscillator DC bias. It's also unclear if the oscillator can drive 2x50 ohm load you may want to increase the resistor value.
  11. #11
    Feb 2015
    29
    1,005
    7
    FvM,
    Thank very much.
    Actually the RF is from signal generator with 50 ohms output and transmission line impedance. does that matter?
  12. #12
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    46,040
    263,501
    100
    RF should be ok then.
  13. #13
    Feb 2015
    29
    1,005
    7
    FvM,
    Very sorry, I am back again. I have two questions here:
    1. "Use capacitor to clock oscillator DC bias" mean using capacitor instead of supplied Vcc? if yes, how I may make its circuit?
    2. "you may want to increase the resistor value", I need to increase the resistors value you mean?
    I would like to extend many thanks for your huge help.
