Which transformers can pass approvals testing rergarding isolation voltage testing?
T
treez
Our contractor designed a 10W, 24Vout, offline Flyback SMPS for 240VAC input. He had a split primary and a bias coil on the primary side, both wound with enamelled copper wire. He also had a secondary of Triple Insulated wire.
He used an SMD transformer which was EFD25 (Page 423 of the below Ferroxcube datasheet).
This failed approvals testing involving testing at 3.5kV for 1 minute.
I am surprised about this, since the secondary was wound with triple insulated wire.
Is it not possible to wind a transformer to pass “3.5Kv for one minute” with the EFD25 transformer?
The approvals house also told us that the PTH version of this transformer would also result in failure. (PTH version is on page 422 of the below datasheet)
The strange thing is that an offline flyback wound on the PQ26/25 core, can pass the “3.5Kv for one minute” approvals test.
Do you know how we can find out which of the transformer bobbins, shown in the ferroxcube datasheet below , can be wound to pass the “3.5Kv for one minute” regulation?
I thought that having a secondary made of triple insulated wire was enough? (obviously including the 8mm primary to secondary gap)
Ferroxcube ferrite datasheet:
EFD25 former is on page 422 and 423....
PQ2625 bobbin is on page 732....
https://www.ferroxcube.com/en-global/download/download/11
i do not think the issue is the bobbin
i think the issue is spacing
the only 8mm spacing i see on the bobbin you called out on page 732 is between the left side and the right side of the top view (drawing on the left)
if left to right pins is the separation between primary and secondary, i suggest you do a top and bottom separation - 25.4 mm
as for the triple insulated wire, what is its rating?
maybe double insulated on primary and on secondary - net 4 layers, assuming it will fit.
TEX-ELZ Triple insulated wire by Furukawa is surely rated to 3.5kv for one minute?
https://www.furukawa.co.jp/tex-e/en/product/texe_feature.html
There is easily >8mm of spacing between primary and secondary pins of the EF25 former, so i cannot understand why this has failed approvals?
I suspect that the problem is something to do with the creepage distance from the point where the triple insulated wire is terminated (on the former pin), to the place in the bobbin, where the coils of primary connected enamelled copper wire are situated. I am not sure, with any bobbin, how one is supposed to be able to measure what this would be (ie, whether it could be made more than the required 8mm).
Quite frankly, I would be amazed if the EFD25 wound transformer flashed over during “3.5kv for one minute” approvals testing, so I am not quite sure how the approvals body have managed to assure that we have failed?
Did you design the transformer yourself? What's the clearance between primary windings and secondary terminals? If it's actually an isolation failure of TIW, I suspect a handling problem.
Yes, and as discussed, its primary, bias and secondary with TIW.
The primary bias coil is the last to be wound on it, (so its the top layer)
The creepage or clearance from secondary termination terminals, to the primary coils on the bobbin is hard to measure.
It's necessary to design the transformer with sufficient clearance in this place. By the way, what's the safety specification (overvoltage category, basic or reinforced isolation?
Reactions: treez
    T
no disrespect intended
copied and pasted from the Furukawa Electric Company website you quoted:
Certified as reinforced insulation; three layers can resist up to 3,000 ACV for one minute.
Reactions: treez
    T
I'm assuming the TIW insulation didn't fail, unless it was damaged during handling (as FvM suggests). Was insulating tubing used to protect the windings as they terminate to the pins?
What was the pinout? Did they add any slots to the PCB? Could have been insufficient creepage between pins. Though if it didn't meet 8mm creepage than it should have failed before even bothering with a hipot test.
Reactions: treez
    T
Thanks, the pinout is as attached. There was tubing used yes.
As you know, There is easily 8mm betweeen primary pins and secondary pins.
Thanks, as you know, there is no need for slotting as there is more than 8mm from primary pins to secondary pins.
Its our PCB and we didnt slot it.
Repeating myself from above...
I am thinking there must be a list of common off-the-shelf formers which cannot pass "1 minute at 3.5kv " regulations?
Its certainly needed, we are having to rip up our whole PCB because of this, because the alternative , conforming EFD25 derived former is bigger than our ferroxcube EFD25 one.
I am quite surprised that there are offtheshelf bobbins which are not possible to conform to "One minute at 3.5kv" regulations.
Unless you have additional spacers, the clearance between winding and SMD pin isn't larger than about 5 mm.
Reactions: treez
    T
as i read the ferroxcube data sheet, page 423 (acrobat reader page 424)
the surface mount pad layout has 2 mm wide pads on 3.75 mm centers
therefore the separation between pads is 1.75 mm
the separation between the primary (pins 1,2,3 in schematic) and the secondary (pins 9 and 10)
is 28 mm and should not be an issue
the separation between the primary (pins 1,2,3 in schematic) and the aux (pins 5 and 6)
depends on pin 4
if pin 4 was not removed carefully, and the pad is on the PWB for pin 4, then the spacing is
1.75 mm from pin 3 to pin 4 and 1.75 mm from pin 4 to pin 5, or 3.5 mm
if pin 4 was removed carefully, and the pad is not the PWB for pin 4, then the spacing is
1.75 mm from pin 3 to pin 4 and 1.75 mm from pin 4 to pin 5, plus 2 mm for pin4, or 5.5 mm
usual test like this ties pins 1,2,3 together, and 9 and 10 together and apply the 3.5 kV
between 1,2,3 and 9,10
how were 5 and 6 treated? primary or secondary?
are there and scorch/burn marks to indicate where the breakdown occurred?
Reactions: treez
    T
5 and 6 are primary bias.
I am not sure if their were scorch marks, they just told us we failed.
If it goes over 3mA when 3.5kv is applied for one minute then its a fail.....
..presumably if we had wound all primary and secondary turns with TIW then we would have been OK?
With TIW used for secondary winding, the critical clearance is pin 9/10 to primary windings, including aux. Changing the secondary pins to 7/12 slightly increases the clearance. Or use additional tape.
Yes, but does it fit?
Reactions: treez
    T
