[ARM] Running emwin on st7735
monjiemegoo
Newbie level 6
hellow guys
i have a JHD-TFT1.8-16A lcd with st7735 driver in it. i want to run emwin on this lcd using a lpc1788 board. my board has a 32mb external ram and i am sure the ram config is ok. i write the below code to run emwin. but nothing happend when i use gui_setbackcolor function.
please if some one knows whats wrong help me. i know this lcd has a ic driver (st7735) but iam not sure this is the right way to connect emwin to ic driver. what is wrong in this code?
if someone know a refrence that can help me please introduce to me.
thanks.
Code C# - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
241
242
243
244
245
246
247
248
249
250
251
252
253
254
255
256
257
258
259
260
261
262
263
264
265
266
267
268
269
270
271
272
273
274
275
276
277
278
//lcdconfig.c
#include "common.h"
#include "GUIDRV_Lin.h"
#include "GUIDRV_FlexColor.h"
*       Layer configuration (to be modified)
// Physical display size
#define XSIZE_PHYS 160
#define YSIZE_PHYS 128
#define EXTERNAL_RAM_BASE_ADDRESS    0xA0000000
#define VRAM_ADDR        EXTERNAL_RAM_BASE_ADDRESS
// Color conversion
#define COLOR_CONVERSION GUICC_565
// Display driver
#define DISPLAY_DRIVER GUIDRV_FLEXCOLOR
#define DISPLAY_ORIENTATION (GUI_MIRROR_Y)
*       Configuration checking
#ifndef   VRAM_ADDR
  #define VRAM_ADDR 0
#endif
#ifndef   XSIZE_PHYS
  #error Physical X size of display is not defined!
#endif
#ifndef   YSIZE_PHYS
  #error Physical Y size of display is not defined!
#endif
#ifndef   COLOR_CONVERSION
  #error Color conversion not defined!
#endif
#ifndef   DISPLAY_DRIVER
  #error No display driver defined!
#endif
#ifndef   DISPLAY_ORIENTATION
  #define DISPLAY_ORIENTATION 0
#endif
*       Static code
*       _InitController
* Purpose:
*   Should initialize the display controller
static void _InitController(void) {
    ST7735_Init();
*       _SetVRAMAddr
* Purpose:
*   Should set the frame buffer base address
static void _SetVRAMAddr(void * pVRAM) {
  LPC_LCD->UPBASE = (uint32_t)pVRAM & ~7UL;
  //LPC_LCD->LPBASE = (uint32_t)pVRAM & ~7UL;
*       _SetOrg
* Purpose:
*   Should set the origin of the display typically by modifying the
*   frame buffer base address register
static void _SetOrg(int xPos, int yPos) {
    (void)xPos;
  // Set start address for display data and enable LCD controller
    LPC_LCD->UPBASE = VRAM_ADDR + (yPos * XSIZE_PHYS * 2);  // Needs to be set, before LCDC is enabled
*       _SetLUTEntry
* Purpose:
*   Should set the desired LUT entry
static void _SetLUTEntry(LCD_COLOR Color, U8 Pos) {
  /* TBD by customer */
*       Public code
*       LCD_X_Config
* Purpose:
*   Called during the initialization process in order to set up the
*   display driver configuration.
int tmp2;
void LCD_X_Config(void) {
  GUI_DEVICE * pDevice;
  GUI_PORT_API PortAPI = {0};
  CONFIG_FLEXCOLOR Config = {0};
  // Set display driver and color conversion for 1st layer
  pDevice = GUI_DEVICE_CreateAndLink(DISPLAY_DRIVER, COLOR_CONVERSION, 0, 0);
  // Display driver configuration, required for Lin-driver
  if (LCD_GetSwapXY()) {
    LCD_SetSizeEx (0, YSIZE_PHYS, XSIZE_PHYS);
    LCD_SetVSizeEx(0, YSIZE_PHYS, XSIZE_PHYS);
  } else {
    LCD_SetSizeEx (0, XSIZE_PHYS, YSIZE_PHYS);
    LCD_SetVSizeEx(0, XSIZE_PHYS, YSIZE_PHYS);
  LCD_SetVRAMAddrEx(0, (void *)VRAM_ADDR);
     PortAPI.pfWrite8_A0  = ST7735_cmd;
   PortAPI.pfWrite8_A1  = ST7735_write;
     PortAPI.pfWriteM8_A0 = ST7735_cmdM;
     PortAPI.pfWriteM8_A1 = ST7735_writeM;
    GUIDRV_FlexColor_SetFunc(pDevice, &PortAPI, GUIDRV_FLEXCOLOR_F66709, GUIDRV_FLEXCOLOR_M16C0B8);
  Config.Orientation = DISPLAY_ORIENTATION;
  GUIDRV_FlexColor_Config(pDevice, &Config);
  // Set user palette data (only required if no fixed palette is used)
  #if defined(PALETTE)
    LCD_SetLUTEx(0, PALETTE);
  #endif
*       LCD_X_DisplayDriver
* Purpose:
*   This function is called by the display driver for several purposes.
*   To support the according task the routine needs to be adapted to
*   the display controller. Please note that the commands marked with
*   'optional' are not cogently required and should only be adapted if
*   the display controller supports these features.
* Parameter:
*   LayerIndex - Index of layer to be configured
*   Cmd        - Please refer to the details in the switch statement below
*   pData      - Pointer to a LCD_X_DATA structure
* Return Value:
*   < -1 - Error
*     -1 - Command not handled
*      0 - Ok
int LCD_X_DisplayDriver(unsigned LayerIndex, unsigned Cmd, void * pData) {
  int r;
    unsigned long Addr, BufferSize;
    GUI_USE_PARA(LayerIndex);
  GUI_USE_PARA(pData);
  switch (Cmd) {
  // Required
  case LCD_X_INITCONTROLLER: {
    // Called during the initialization process in order to set up the
    // display controller and put it into operation. If the display
    // controller is not initialized by any external routine this needs
    // to be adapted by the customer...
    _InitController();
    return 0;
  case LCD_X_SETVRAMADDR: {
    // Required for setting the address of the video RAM for drivers
    // with memory mapped video RAM which is passed in the 'pVRAM' element of p
    LCD_X_SETVRAMADDR_INFO * p;
    p = (LCD_X_SETVRAMADDR_INFO *)pData;
    _SetVRAMAddr(p->pVRAM);
    return 0;
  case LCD_X_SETORG: {
    // Required for setting the display origin which is passed in the 'xPos' and 'yPos' element of p
    LCD_X_SETORG_INFO * p;
    p = (LCD_X_SETORG_INFO *)pData;
    _SetOrg(p->xPos, p->yPos);
    return 0;
  case LCD_X_SETLUTENTRY: {
    // Required for setting a lookup table entry which is passed in the 'Pos' and 'Color' element of p
    LCD_X_SETLUTENTRY_INFO * p;
    p = (LCD_X_SETLUTENTRY_INFO *)pData;
    _SetLUTEntry(p->Color, p->Pos);
    return 0;
  case LCD_X_ON: {
    // Required if the display controller should support switching on and off
    return 0;
  case LCD_X_OFF: {
    return 0;
  default:
    r = -1;
  return r;
/*************************** End of file ****************************/
Code C# - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
//guiconfig.c
*       Defines
// Define the available number of bytes available for the GUI
volatile unsigned long *emwin_memory_pointer = (unsigned long *)(EXTERNAL_RAM_BASE_ADDRESS + 16 * 1024 * 1024);
#define EMWIN_MEMORY_SIZE  (16 * 1024 * 1024)
*       Public code
*       GUI_X_Config
* Purpose:
*   available memory for the GUI.
void GUI_X_Config(void) {
  // Assign memory to emWin
  GUI_ALLOC_AssignMemory(emwin_memory_pointer, EMWIN_MEMORY_SIZE);
    // To reduce the library size we shouldn't use fonts:
//  // Set default font
//  GUI_SetDefaultFont(&GUI_FontBTitr37);
Code C# - [expand]
8
9
10
11
//main.c
int main()
    GUI_Init();
    GUI_SetBkColor(GUI_RED);
    GUI_Clear();
    while(1)
