Results 1 to 6 of 6
    Newbie level 5
    Points: 124, Level: 1
    May 2019
    10
    124
    Instrumentation AMP Virtual short.
    If I am using an instrumentation amplifier such as the AD8421 in what situations can I make an assumption of a virtual short across the input terminals of the amplifier? For example will the + terminal be ground?
    https://www.analog.com/media/en/tech...ets/AD8421.pdf
    I thought that the virtual short / ground had to do when there was feedback as part of the amplifier. Thanks for any clarification.
    Points: 24,286, Level: 37
    barry's Avatar
    Mar 2005
    California, USA
    4,657
    24,286
    37
    Re: Instrumentation AMP Virtual short.
    Yes, it's a virtual short. If you actually analyze the circuit, you'll see that as the IA open-loop gain goes to infinity, the voltage at the two inputs becomes the same.
    Points: 260,253, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,447
    260,253
    100
    No, instrumentation amplifier works different than basic OP. No "virtual short" involved. The sketched schematic has no relation to instrumentation amplifiers.
    Points: 339, Level: 3
    Feb 2018
    7
    339
    One of these assumptions is called the virtual short circuit, or just virtual short. Actually, this is not one of the fundamental characteristics of an ideal op amp. Rather, the virtual short is a theoretical situation that arises from one of the fundamental characteristics of an ideal op amp, namely, infinite open-loop gain.
    Let’s imagine that we have an op amp connected as an inverting amplifier. As is almost always the case with op amp circuits, the functionality is based on the use of negative feedback..
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,447
    260,253
    100
    Agree with your explanation. But it doesn't apply to instrumentation amplifier like AD8421. It has no external feedback.
    Advanced Member level 3
    Points: 5,888, Level: 18
    Feb 2014
    838
    5,888
    18
    Right, no virtual ground for an inst amp.
    They act as a fixed differential in to differential out gain block with high input impedance.
    This inst amp defaults to gain of 1 which can be increased by adding a single external R. The R to gain table is on sheet 20.
    Learn a simulator: LTSpice is provided for free by Analog and includes a model and application circuit for AD8421.
