Results 1 to 7 of 7
    Full Member level 6
    Points: 4,098, Level: 15
    Oct 2006
    392
    4,098
    15
    RFID Coil design and Simulation
    hi
    I need some design application notes for RFID coils. Can i simulate coil in ADS or HFSS etc. Is there any example available for ADS momentum. Is it possible to beam forming using coil arrays?
    Points: 14,451, Level: 29
    Apr 2014
    2,255
    14,451
    29
    Re: RFID Coil design and Simulation
    What RFID frequency band? UHF?
    Full Member level 6
    Oct 2006
    392
    4,098
    15
    i want to use 390MHz.
    Apr 2014
    2,255
    14,451
    29
    What I have seen for UHF RFID readers are patch antennas.
    EM simulation is possible and useful, planar simulation with ADS Momentum is a good starting point.
    A former collegue designed this using CST:
    https://patents.google.com/patent/DE102012101443A1/zh
    Points: 34,870, Level: 45
    7 years registered Created Blog entry Created Album pictures
    SunnySkyguy's Avatar
    Sep 2007
    Richmond Hill, ON, Canada
    6,729
    34,870
    45
    Blog Entries
    7
    A best design is easily achieved with good test specs™
    A better question deserves a better answer. ™
    ... so include all your acceptance criteria ( values, % tolerance) and assumptions in your question or any design.
    ... Tony Stewart EE since 1975
    - slightly north of Toronto
    Full Member level 3
    Points: 3,265, Level: 13
    Dec 2007
    187
    3,265
    13
    Freespace wavelength at 390 MHz is 77 cm. I guess you are talking about coils for near-field applications.
    Both ADS Momentum and HFSS can help for the coil design, though the former should be faster and easier in this case.
  7. #7
    Full Member level 6
    Oct 2006
    392
    4,098
    15
    Thanks for reply.
    Yes i am talking about near field applications.
