RFID Coil design and Simulation
adnan012
Advanced Member level 1
hi
I need some design application notes for RFID coils. Can i simulate coil in ADS or HFSS etc. Is there any example available for ADS momentum. Is it possible to beam forming using coil arrays?
i want to use 390MHz.
Freespace wavelength at 390 MHz is 77 cm. I guess you are talking about coils for near-field applications.
Both ADS Momentum and HFSS can help for the coil design, though the former should be faster and easier in this case.
Thanks for reply.
Yes i am talking about near field applications.
