STM32 16bit wav player using Dac
SS1_Raptor
Junior Member level 1
Hello friends good time,
I easily play 8bit wav file using DAC in STM32
But when play 16bit wav Anomalous sounds can be heard
tested several sample rate 8k,16k,32kThey all had anomalous sounds
I use the dac 12bit right alignment
MCU Clock 48MHZ
Read Data From MicroSD
in system that play very well 8bit wav .
Someone can help me find the problem?
i look at this in a simple way
you have a 16 bit wav in a 12 bit DAC
what happens to the other 4 bits?
if the data is 16 bit, using 12 bits loses something
you use the DAC right aligned
is the data right or left aligned?
what is an anomalous sound?
this is my code ( In conceptual terms )
Code dot - [expand]
buffer[x]>>=4; /* Skip 4bit LSB */
buffer[x] = buffer[x]^0x800; /* Convert Unsigned to Signed */
Dac_Register(12bitLeftAligned) = buffer[x];
but not working and have very bad voice
Please help friends who have experience in this area
I'm not sure exactly what that does but I suspect the '=' shouldn't be there.
I'm also not sure you should convert to signed at all, does the DAC accept signed numbers?
