Results 1 to 7 of 7
    Junior Member level 1
    Points: 182, Level: 2
    Apr 2019
    17
    182
    PID algorithm for BLDC speed control
    Hello guys,
    I have been working with PID algorithm to control bldc motor speed. currently I am tuning the gain kp,ki,kd values with a predefined RPM as setpoint or reference value. But the real application is controlling with bike throttle here,
    my question is how to convert the throttle value to RPM?
    and what will be the range of RPM? because the rpm will down in dynamic load condition right.
    Motor spec- 48v 1kW bldc motor
    rated rpm -3000
    If u guys have any ideas kindly share it.
    hoping for a reply
    thanks in advance
    Points: 261,068, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,608
    261,068
    100
    Re: PID algorithm for BLDC speed control
    I expect that the throttle value is converted to torque or power rather than speed setpoint. You probably don't need a PID controller, except for speed limit control if required.
    Apr 2019
    17
    182
    I thought PID controller is needed for Dynamic load condition to maintain the rpm
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,608
    261,068
    100
    E-bike is usually not utilizing speed control, neither a car does.
    Apr 2019
    17
    182
    then how to maintain constant speed at dynamic load conditions. Are there any different technique to do so?
    Points: 78,377, Level: 68
    Apr 2014
    15,899
    78,377
    68
    Torque / load will always have an influence on motor RPM unless it is a synchronous motor (stepper motor).
    A BLDC motor with permanent magnet also is a synchronous motor. Thus RPM depends on fundamental frequency of applied signals.
    Keeping frequency cinstant will keep RPM constant .... as long as the torque does not cause a motor stall.
    There are several issues you have to consider:
    * what's the exoected RPM range, and how much deviation do you tolerate.
    * what's the expected load (torque) range do you expect?
    * what exact motor do you use?
    * what power stage (BLDC controller) do you use?
    * maybe you should give additional information about your application (what is it used for....)
  7. #7
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,608
    261,068
    100
    The driver is controlling the speed with throttle, unless a cruise control option is keeping constant speed. I never heard about cruise control for E-Bikes.
