Results 1 to 5 of 5
    Newbie level 1
    Points: 131, Level: 1
    Jun 2019
    Erina NSW
    7
    131
    Windows 7: Headset Sound In Not Working w/ Skype
    Hi!
    I have an HP Pavillion HPE (h8-1380t) running Windows 7 Pro (64-bit) and I have a headset plugged to the top of the computer. FYI, on the top, the computer there are 4 ports: headset out, headset in (mic), and 2 USB ports. Here's what is happening:
    a – I can listen to YouTube videos.
    b – When I use Skype, my voice is herd (i.e., the mic works) but I do not hear anything.
    I tested the speakers using Tools > Options > Audio Settings > Speakers (which is set to Communications Headphones, IDT High Def..., Auto Volume) and I hear the sound.
    What's wrong?
    Thank you!
    Points: 53,731, Level: 56
    Apr 2011
    Minneapolis, Minnesota, USA
    13,098
    53,731
    56
    Re: Windows 7: Headset Sound In Not Working w/ Skype
    Can you tell if Skype receives the sender's audio?
    Does Skype have its own setting (apart from your Sound control panel) to choose speaker, or HDMI, or headphones?
    Newbie level 3
    Points: 28, Level: 1
    Isabella020's Avatar
    Oct 2019
    islamabad
    28
    Quote Originally Posted by victorjohn9211 View Post
    Hi!
    What's wrong?
    Thank you!
    update skype version use new skype version if you use new go to setting and change the auto option if you face problem Skype suggested to uninstall and, then, re-install Skype, which I did. But, the problem is still there.
    Banned
    Points: 112, Level: 1
    Nov 2019
    London
    16
    112
    You should try to uninstall your skype version and install new skype version then use skype to check your voice is heard or not.
    Newbie level 1
    Points: 13, Level: 1
    Jan 2020
    13
    windows 7 rip, yes?
