[SOLVED] Single or dual supply operation
Junus2012
Italy
Dear friends,
Will be any difference in op-amp peerformance and characteristics if I use to connect it with single supply operation or dual supply ?
I am using the 3.3 V CMOS technology in my design
for single supply I use VDD = 3.3 V and VSS = 0 V
for dual supply it should be VDD=1.65 V and VSS = -1.65 V
Thank you
Best Regards
Short answer: as long as it is biased within its common-mode input range, it makes no difference.
My answer:
Since the Opamp has no GND pin ... it simply does not know whether it is dual or single supplied.
--> There is no difference in operation.
Thus every Opamp can be operated in single supply mode as well as in dual supply mode.
It's just a different point of view.
