Page 2 of 2 FirstFirst 1 2
Results 21 to 23 of 23
  1. #21
    Newbie level 6
    Points: 79, Level: 1
    Sep 2019
    14
    79
    Re: Shift register implementation and use of its value
    Quote Originally Posted by ads-ee View Post
    The way you wrote the shift register code won't work unless there is other code which you neglected to show that takes shift_reg and feeds it back into the input_data. Unless you show everything to do with the code all the way back to inputs and outputs of the module, we can only comment on the code you provide with your question.
    This is how I have written:
    parameter input_width = 8;
    parameter bit_width = 1; //in this case to shift 1 bit at a time
    input [input_width-1:0] input_data;
    reg    [input_width-1:0] shift_reg;
    always @(posedge CLK or negedge RST)
    begin
    if (!RST) shift_reg <= input_data;
    else       shift_reg <= {bit_width{1'b0}}, shift_reg[input_width-1:bit_width]};
    end
    I am running this code with different input_data values and it works. Even with different widths of "bit_width" it works by shifting. How could that be possible?
    This is all the code thats related to this operation.
  2. #22
    Points: 31,607, Level: 43
    ads-ee's Avatar
    Sep 2013
    USA
    7,310
    31,607
    43
    Quote Originally Posted by rogger201 View Post
    Why?
    I tried doing this
    always@(posedge clock) begin
    if (reset) shift_reg = input_data;
    else        shift_reg = {1'b0, input_data[7:1]};
    So all of the data gets loaded in in the first cycle after reset .
    This way its achieved in one cycle. Either way I want to use the last bit so I just keep shifting in 0's every clock. Am I going wrong somewhere?
    begin
    end
    [/CODE]
    Notice there is a difference in the RHS of the two code snippets you posted (highlighted in red). The top one is not a shift register no matter how much you claimed it was.
    The second is a shift register. You should proof read your code more carefully to avoid misunderstandings like this, or at a minimum READ others posts carefully so you can correct the mistake sooner.
  3. #23
    Newbie level 6
    Sep 2019
    14
    79
    Sorry about that. I i will mark this question solved. Thanks for your help.
