Results 1 to 4 of 4
    Full Member level 6
    Points: 3,339, Level: 13
    Jul 2010
    Germany
    335
    3,339
    13
    Real use of left and right alignment in ADC
    Hello edaboard members,
    I am using STM32F103. I want to know what is the real use of a left and right alignment of adc result. How does it help? What should be chosen ideally?
    I googled but unfortunately could not get a concrete answer.
    Thanks in advance,
    Embedded_Geek
    "I have no special talents. I am only passionately curious." Albert Einstein
    Regards,
    Embedded_Geek
    Points: 9,145, Level: 22
    Easyrider83's Avatar
    Oct 2011
    Tallinn, Estonia
    1,599
    9,145
    22
    Re: Real use of left and right alignment in ADC
    For 10 bit adc, if you need all 10 bits you are reading low and high value of conversion result using right alignment. If you need only 8 bits, you use left alignment and take only high value.
    Love me or hate me. All infractions will be ignored.
    Points: 77,827, Level: 68
    Apr 2014
    15,774
    77,827
    68
    Some think in LSBs. They like to use right aligned ADC values.
    I like to think in "full scale" ...i like left aligned.
    Some ADCs are available in 12, 14, 16 bit versions. If you use left aligned you don't need to change code.
    Banned
    Points: 78, Level: 1
    Sep 2019
    nepal
    10
    78
    Real use of left and right alignment in ADC For 10 bit adc, if you need all 10 bits you are reading low and high value of conversion result using right alignment. If you need only 8 bits, you use left alignment and take only high value.To explain the use of the ADC, let's look at a basic example taking a single reading. ... ADFM = 1; //ADC result is right justified ADCON0bits. ... to the left by 8 and adding the ADRESL.If we do not wait at least 5us, the reading will be lower than the actual voltage applied to the pin.
