Results 1 to 12 of 12
    Points: 254, Level: 3
    fixit7's Avatar
    Jul 2019
    50
    254
    Runtime of clock using alkaline D cells instead of AA batteries
    I have a wall clock that uses 2 AA batteries.
    I would like to use a transformer, but I get frequent power outages.
    The clock uses about 30 mAh.
    It lasts about 2 months before it starts losing time. (Around 2.0 volts for the 2 batteries.)
    If I go with 2 D cell batteries, what kind of run time would be typical?
    Points: 24,248, Level: 37
    barry's Avatar
    Mar 2005
    California, USA
    4,653
    24,248
    37
    Re: Runtime of clock using alkaline D cells instead of AA batteries
    Do the math: Alkaline AAs have 2400mA-H of capacity; Ds have 13000mA-H. These values depend somewhat on the load.
    fixit7's Avatar
    Jul 2019
    50
    254
    Quote Originally Posted by barry View Post
    I assume that Time(H) = Capacity(Ah)/Current(A) equals a final battery voltage of 0 volts which will not work in my case.
    I need a calculation for an ending voltage of around 2.0 volts.
    barry's Avatar
    Mar 2005
    California, USA
    4,653
    24,248
    37
    Quote Originally Posted by fixit7 View Post
    Then you're going to need to get the manufacturers curves.
    Or, use some of your reasoning power . If the D has 13000 and the AA has 2400==> 13000/2400=x/2months
    Points: 14,929, Level: 29
    schmitt trigger's Avatar
    Apr 2013
    2,482
    14,929
    29
    For alkaline batteries, the capacity is NEVER calculated to zero volts, but an end voltage of 0.9 volts per cell.
    But from a battery datasheet, check the end voltage value. The 0.9 volts I gave you is from memory. It could be a little higher or a little lower.
    My batteries are recharged by "Helpful Post" ratings.
    fixit7's Avatar
    Jul 2019
    50
    254
    Ok, I found the data sheet. I see the capacity is 15,000 Mah.
    So, according to the table, if a device using 120 Mah, it would last about 80 hrs.
    Since the clock uses 30 Mah, that would be about 480 hrs.
    480 hrs = 20 days.
    That does not compute as AAs last around 60 days.
  7. #7
    Advanced Member level 2
    Points: 5,164, Level: 17
    ZASto's Avatar
    Jan 2008
    Messy Corner, 44°47'31.56"N, 20°28'9.16"E
    617
    5,164
    17
    15000mAh / 2400mAh = 6.25
    60days * 6.25 = 375days
    How this compute :D
    Make no mistake between my personality and my attitude.
    My personality is who I am.
    My attitude depends on who you are.
  8. #8
    Points: 77,645, Level: 67
    Apr 2014
    15,737
    77,645
    67
    Please use correct units.
    * capacity is 15,000 Mah. --> 15,000 mAh
    * device using 120 Mah --> 120 mA (without "h")
    * and so on..
    How do you come to 80 h?
    My calculator says this is 120 mA x 80 h = 9,600 mAh ...
    * are you sure the 30 mA are at 1.2V (as the 120mA in the chart)?
    * you need to recognize: the lower the current, the higher the usable energy.
    * the usable energy will differ from cell to cell
    * the usable energy depends on cell type (chemistry)
    * the usable energy depends on brand and exact type (model)
  9. #9
    Points: 260,175, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,437
    260,175
    100
    Doesn't this demand for a transformer supply with battery backup? The battery is only discharged during power failure then.
  10. #10
    Full Member level 6
    Points: 2,513, Level: 11
    Nov 2016
    398
    2,513
    11
    I'm guessing the 2400 mah rating for AA is one battery. Fixits clock uses two AA batteries. Would this not be 4800 mah capacity.
    Never mind, evidently it's 3 volt series connected batteries.
    https://www.digikey.com/en/resources...r-battery-life
    With this calculator I plugged in 2400 mah and 1.16 ma. This gives a run time of 1448 hrs. , or roughly 2 months.
  11. #11
    Points: 53,679, Level: 56
    Audioguru's Avatar
    Jan 2008
    Toronto area of Canada
    8,745
    53,679
    56
    Some name-brand alkaline D cells have a little C cell inside with the C cell capacity. Few D cells are sold today.
    Some Chinese alkaline D cells have anything that is cheap inside.
  12. #12
    fixit7's Avatar
    Jul 2019
    50
    254
    Thanks for all the responses. They helped.
