Results 1 to 14 of 14
    Advanced Member level 2
    Points: 2,211, Level: 10
    Aug 2016
    578
    2,211
    10
    HEI primary current duration
    Can the dwell time and period on the primary side be any duration so long as it abides by the maximum peak current?
    Manufacturer's Part Number:D3070
    Primary Resistance:0.350 ohms
    Coil Internal Construction:Epoxy
    Maximum Voltage:50,000 V
    Turns Ratio:85:1
    Secondary Resistance:8.30K ohms
    Inductance:2.80 mH
    Peak Current:7.9 amps
    Spark Duration:1.5 mS
    https://www.summitracing.com/parts/pnx-d3070
    Member level 5
    Points: 1,016, Level: 7
    May 2017
    Canada
    84
    1,016
    7
    Re: HEI primary current duration
    Yes but you need to allow extra time- for the spark to finish, which can vary a bit due to plug gap and plug+cable resistance, misfires etc. Also, dwell varies with system voltage so assume 11V say, not 14V; and you have some wiring and IGBT resistance, so the current ramp up is never as fast as theoretical.
    Say 2msec dwell max. and 1.5msec for spark duration, so 3.5msec cycle time around 300Hz. You can go faster if you compromise dwell time. This is another reason for coil-on-plug technology which allows higher engine speeds.
    That gives a single HEI coil on a V8 at 300Hz is (I think) 4,500RPM. If you wanted 6,000 RPM you'd have to live with the 4.5A that you can ramp up to in the available time.
    Aug 2016
    578
    2,211
    10
    Do ignition drivers typically adjust the falling edges during ordinary operation to prevent excessive back emf spikes?
    Points: 260,175, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,437
    260,175
    100
    Back emf is is causing the ignition spark (fly-back converter principle), you don't want to cut it.
    Aug 2016
    578
    2,211
    10
    Would using straight square waves on the primary, but keeping within the rated peak current damage the HEI?
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,437
    260,175
    100
    No damage, but also no high voltage output. Primary fly-back voltage needs to go up to 600V for 50000V secondary.
  7. #7
    Aug 2016
    578
    2,211
    10
    What was meant is reducing the falling edge to keep it below the many thousands of volts it will rise to thus lowering the power dissipation of the RC snubber.
    There has to be a large back emf on the primary to make the rated HV on the secondary.
    Automotive ignition drivers use ramps with dwell time to prolong primary charging durations, not squares as the ramps raise the current into the primary gradually.
    Wouldn't the very sharp rising edges of square waves destroy the primary winding?
  8. #8
    Banned
    Points: 76, Level: 1
    Sep 2019
    nepal
    10
    76
    The High Energy Ignition System (HEI) has undergone many improvements .... A duration of 5 ms allows the primary current to build to 3.8 amperes.HEI primary current duration Say 2msec dwell max. and 1.5msec for spark duration, so 3.5msec cycle time around 300Hz. You can go faster if you compromise dwell time. This is another reason for coil-on-plug technology which allows higher engine speeds.
  9. #9
    Aug 2016
    578
    2,211
    10
    For GM HEI coils are dwell times adjusted by an onboard processor?
  10. #10
    Points: 11,046, Level: 25
    Aug 2015
    1,790
    11,046
    25
    for a single coil the dwell time is limited by the rpm, lots of dwell avail at idle speeds - less so at 7000 rpm ( 3500 rpm on dizzy ) as the ignition system cannot accurately predict when the exact spark should be, the coil must be energised up until the spark is required = igbt off = flyback volts on LV side of coil ( up to 250V for a 350V igbt ) = 20,000V on HV side before plug strikes and V falls to lit (plasma) value ...
  11. #11
    Aug 2016
    578
    2,211
    10
    Min automotive rpm = ~700rpm - 1000RPM max dwell for 700rpm = ~84mS long which is plenty to to burn up a low resistance primary HEI coil. According to attached document resistors on the primary used were used later replaced by varying dwell time with control module.
    Ignition gate drivers can have long dwell durations.
    https://www.onsemi.com/pub/Collatera...100_F085-D.PDF
    Is there an industry standard maximum dwell time for HEI coils?
    HEI.pdf
  12. #12
    Aug 2015
    1,790
    11,046
    25
    my reply concerned a single coil system - you appear to have misread it ...
  13. #13
    Member level 5
    May 2017
    Canada
    84
    1,016
    7
    You have to shut off the IGBT at precisely the right (spark) time, so you are always calculating backwards when to start the next dwell period.
    If you have reached max. dwell time before spark time, you have to shut off the IGBT to protect it and the coil from overcurrent. But if you then don't want a backfire, "soft-shutdown" involves gradually lowering gate voltage (Fig. 15).
    MOSFET's are much faster, that is why I mentioned they can turn off too fast and cause insulation breakdown within the coil's leakage inductance. I don't see mosfets used in automotive ignition systems also because their on-resistance is too high for HV parts.
    Ignition IGBT's are slow devices compared to MOSFETS. Example Fairchild FGB3040G2-F085 400V internal clamp, 25A, 5-15usec turnoff.
    On-semi (Fairchild) AN-8208 Introduction to Automotive Ignition Systems with good research references listed at the end.
  14. #14
    Aug 2015
    1,790
    11,046
    25
    certainly you will need soft turn off of the igbt to avoid a spark - if you are calculating dwell periods based on current rpm -
