Results 1 to 6 of 6
    Newbie level 2
    Points: 23, Level: 1
    Sep 2019
    23
    lcd interfacing with pic 16f877a
    hi dear,
    i am new to pic and ccs compiler. i write a code for lcd interfacing and simulating on the proteus. lcd showes nothing. guide me please what and where is the error? the code is as following;
    Code C - [expand]
    8
    9
    10
    11
    12
    13
    14
    15
    16
    17
    18
    19
    20
    21
    22
    23
    24
    25
    26
    27
    28
    29
    #include "C:\Program Files\PICC\lcd1.h"
    #define LCD_RS_PIN PIN_C0
    #define LCD_RW_PIN PIN_C1
    #define LCD_ENABLE_PIN PIN_C2
    #define LCD_D4 PIN_C3
    #define LCD_D5 PIN_C4
    #define LCD_D6 PIN_C5
    #define LCD_D7 PIN_C6
    //End LCD module connections
    //#include <16F877A.h>
    #use delay(crystal=20000000)
    #include <lcd1.c>
    void main(){
    set_trix_c(0x00);
      lcd_init();    // Initialize LCD module
      while(TRUE){
        lcd_putc('\f');
        lcd_gotoxy(4, 1);           // Go to column 4 row 1
        lcd_putc("PIC16F877A");
        delay_ms(2000);
    kind regards
    msanwer
    Points: 12,636, Level: 26
    Apr 2010
    1,918
    12,636
    26
    Re: lcd interfacing with pic 16f877a
    your lcd_init() function should have the 4bit interface and the number of lines in the display related code plus other mode set codes.
    otherwise lcd will not display the characters.
    Points: 8,209, Level: 21
    paulfjujo's Avatar
    Jun 2008
    France 01120
    1,324
    8,209
    21
    hello,
    check if
    lcd_putc(xxxx); is a function to printout a single character (byte) or a string ( serie of byte + zero)
    Newbie level 2
    Sep 2019
    23
    hi dear,
    how to check whether lcd_init() is 4 bit or 8 bit interfaced?
    Points: 81,387, Level: 69
    2nd Helpful Member
    betwixt's Avatar
    Jul 2009
    Aberdyfi, West Wales, UK
    13,343
    81,387
    69
    If the LCD only has 4 data lines connected to the PIC it is a 4-bit interface, if it has 8 data lines connected it is an 8-bit interface.
    Note that the commands and characters are always 8-bit, if you use 4-bit mode it sends the high four bits and low four bits as two transfers instead of one.
    paulfjujo's Avatar
    Jun 2008
    France 01120
    1,324
    8,209
    21
    at first, gives answer to whom want to help you !
    lcd_putc(xxx) can't be used for a simple char AND/OR a string
    you need 2 separate functions.
    the only way is to know the detail of the lcd_init() function
    your can analyse the *.asm or *.lst file resulting after compiling the source
    the best way , is to write yourself this Lcd_init function .
    A LCD is in 8 bit mode by default,
    then you change it by 4 bit mode...
    void LCD_Cmd(Byte Cde)
    {   Byte D2;
        LCD_RS = 0;
        // envois poid fort
         D2 = Cde >> 4;
         LCD_RS = 0;
        Transmet (D2);
    // envois poid faible
        D2= Cde & 0x0F;
         LCD_RS = 0;
        Transmet (D2);
    void Init_LCD_2X16(void)
        Byte Cde;
        LCD_E  = 0;
        LCD_RW = 0;
        LCD_RS = 0;
        Cde= 0x30;             // Mode 8 bit
        LCD_Cmd(Cde);
        DELAY_15MS;
        LCD_Cmd(Cde);        // MSB
        Delay_2Ms;
        Delay_2Ms;
        Delay_2Ms;
        Cde= 0x20;            // mode 4 bit sur B4..B7
        LCD_Cmd(Cde);
        // 2 lignes , carac 5x7  =0x28
        Cde= 0x20;
        LCD_Cmd(Cde);
        Cde= 0x80;
        LCD_Cmd(Cde);
        Delay_2Ms;
        // no cursor
        Cde= 0x00;
        LCD_Cmd(Cde);
        Cde = 0x0C;
        LCD_Cmd(Cde);
        Delay_2Ms;    // delais de 2ms
        //efface display
        Cde = 0x00;
        LCD_Cmd(Cde);
        Cde = 0x01;
        LCD_Cmd(Cde);
