Page 1 of 2 1 2 LastLast
Results 1 to 20 of 27
    Junior Member level 3
    Points: 211, Level: 2
    Apr 2019
    27
    211
    My 12V DC Vending Machine motor rotates 1 extra 360 degree rotation sometimes.
    I have done some changes with the Motor to work with the micro limit switch.
    But the problem is sometimes the motor rotates 1 full 360 degree rotation which is perfectly fine but sometimes motor rotates 2 full or 1 and half rotation which is wrong. I do not know the reason.
    I have attached the circuit diagram and shared the link of video as well
    Here is the imageClick image for larger version.
ID:	155596Click image for larger version.
    Here is the video
    https://drive.google.com/open?id=1N7...6SGHkVWufDT40K
    https://drive.google.com/open?id=1VX...vVZ1yR0UMflJKA
    Points: 12,636, Level: 26
    Apr 2010
    1,918
    12,636
    26
    Re: My 12V DC Vending Machine motor rotates 1 extra 360 degree rotation sometimes.
    The attached block diagram does not give any clue on your design.
    Attach a circuit diagram if possible or a clear block diagram and mention your requirement.
    Points: 52,890, Level: 56
    Apr 2011
    Minneapolis, Minnesota, USA
    12,941
    52,890
    56
    Your Google.drive links do not play a video. Instead they require permission which I was unable to obtain.
    Apr 2019
    27
    211
    I have given the permission
    Quote Originally Posted by srizbf View Post
    Here is the clear block diagram
    I hope everything is clear and now you would help me.
Name:	WhatsApp Image 2019-09-23 at 10.51.13 AM.jpeg
Name:	WhatsApp Image 2019-09-23 at 10.51.13 AM (1).jpeg
    Apr 2011
    12,941
    52,890
    56
    Your videos are visible now.
    Your mechanism looks like the sort of thing that might have a cam or gear with a notch in it. If it doesn't stop after a cycle, it skips the notch and continues for a second cycle.
    The natural question to ask: What makes your motor start a cycle, and what makes it stop?
    Measurements are precise with a microswith. It needs to be positioned exactly right, and be pressed just right, in order to work reliably.
    Apr 2019
    27
    211
    Quote Originally Posted by BradtheRad View Post
    Hello
    Motor Micro limit switch Common is connected to ground (ROW pin of the main board) and NO NC pin of this micro limit switch is connected to Column pin of the main board which has 12V when a signal comes.
    To start a cycle of the motor when we give input to the column, switching is done on the main board and column pin switches to 12V then motor starts and when one cycle is complete and micro limit switch presees, mainboard reads the value and stop the motor.
  7. #7
    Points: 77,731, Level: 67
    Apr 2014
    15,755
    77,731
    67
    Depending on microswitch wiring...at STOP position:
    * it can make the motor to free run (open)
    * or it can make the motor to break (short circuit)
    Maybe in "free run" it passes the notch and starts again..
  8. #8
    Apr 2019
    27
    211
    Hi
    Can you tell me what should be the micros switch wiring so that it will be stopped after one round.
    I have attached the block diagram of existing circuit. please suggest
  9. #9
    Apr 2014
    15,755
    77,731
    67
    I just recognized that your wuring diagram shows the microswitch NC and NO to be shorted. This makes no sense, it makes the switch useless, because the current is never stopped from flowing, either it runs through NC or NO, one of these paths is always closed.
    Try to use NC only.
    If it does not work: try to use NO only
  10. #10
    Apr 2011
    12,941
    52,890
    56
    * Does your motor draw so much current that it causes the supply voltage to droop?
    * Does you motor create noise (glitches) on the supply rails?
    Either of these can cause faults in a control circuit.
  11. #11
    Apr 2019
    27
    211
    Try to use NC only.
    I have used NO but again Motor does not stop when micro switch press.
    NC didn't work
    Try to use NC only.
    I have attached an image of different motor which uses the exact circuit diagram (NO and NC short) which I have followed and it works fine completely but not mine.
Name:	WhatsApp Image 2019-09-23 at 12.40.43 PM.jpeg
  12. #12
    Apr 2019
    27
    211
    My motor takes around 200mA Max.
    Motor does not create noise
  13. #13
    Full Member level 6
    Points: 2,514, Level: 11
    Nov 2016
    398
    2,514
    11
    [QUOTE=sugandha123;1662165]I have used NO but again Motor does not stop when micro switch press.
    NC didn't work
    In your diagram both motors are connected to NO and NC. Did you disconnect one motor , or did you just remove one or the other connectors on microswitch.
  14. #14
    Apr 2019
    27
    211
    [QUOTE=Kajunbee;1662185]
    Quote Originally Posted by sugandha123 View Post
    NC didn't work
    I have changed the microswitch connections only
  15. #15
    Apr 2019
    27
    211
    NC didn't work
    I had one another motor which has different connections so I decided to changes its connection to make it exactly the other wine (White motor)
    Try to use NC only.
    I have main board which has motor control circuit and has row and column to control the row and column of the vending machine.
    I have made changes in motor in two ways:
    A. I have attached an image for circuit diagram
    In this design I have some pros and cons
    PROS: 1. It stops at its home position after one rotation
    2. It detects row and column of the machine
    CONS: 1. Sometime it does not stop at its home position or take more than 1 rotation
    B. I have attached an image of other diagram
    In this design also I have some pros and cons
    PROS: 1. It stops perfectly at its home position after one rotation.
    CONS: 1. It does not detect ROW
    Please suggest What should I follow and what should I made changes in the circuit.
  16. #16
    Apr 2010
    1,918
    12,636
    26
    Test with the above option A with the following changes:
    -Connect to NC contacts.
    -Remove the 100 microfarad capacitor.
  17. #17
    Apr 2019
    27
    211
    Connect to NC contacts means?
    I have shorted NC NO contacts.
    Actually I have another Motor which has same circuit and works completely fine with NO NC shorted.
    So I decided to replicate my motor to that Motor but my motor does not work exactly same like another motor.
  18. #18
    Apr 2019
    27
    211
    I have removed the capacitor but again facing the same issue.
  19. #19
    Full Member level 6
    Nov 2016
    398
    2,514
    11
    http://www.nls.net/mp/volks/schem/wiper.htmhttps://electronics.stackexchange.co...switch-circuit
    I see that the pcb on motor in your video is different than one in photo.
  20. #20
    Apr 2019
    27
    211
    Quote Originally Posted by Kajunbee View Post
    PCB on video and on photo is not different.
    I have changed the circuit which is shown in video and my circuit diagram too which I already posted on this group.
