My 12V DC Vending Machine motor rotates 1 extra 360 degree rotation sometimes.
sugandha123
I have done some changes with the Motor to work with the micro limit switch.
But the problem is sometimes the motor rotates 1 full 360 degree rotation which is perfectly fine but sometimes motor rotates 2 full or 1 and half rotation which is wrong. I do not know the reason.
I have attached the circuit diagram and shared the link of video as well
Here is the video
https://drive.google.com/open?id=1N7ItjeU84JiDAOquAD6SGHkVWufDT40K
https://drive.google.com/open?id=1VX9yncrm6pcr1IBQsNvVZ1yR0UMflJKA
The attached block diagram does not give any clue on your design.
Attach a circuit diagram if possible or a clear block diagram and mention your requirement.
I have given the permission
Here is the clear block diagram
I hope everything is clear and now you would help me.
Your videos are visible now.
Your mechanism looks like the sort of thing that might have a cam or gear with a notch in it. If it doesn't stop after a cycle, it skips the notch and continues for a second cycle.
The natural question to ask: What makes your motor start a cycle, and what makes it stop?
Measurements are precise with a microswith. It needs to be positioned exactly right, and be pressed just right, in order to work reliably.
Hello
Motor Micro limit switch Common is connected to ground (ROW pin of the main board) and NO NC pin of this micro limit switch is connected to Column pin of the main board which has 12V when a signal comes.
To start a cycle of the motor when we give input to the column, switching is done on the main board and column pin switches to 12V then motor starts and when one cycle is complete and micro limit switch presees, mainboard reads the value and stop the motor.
Depending on microswitch wiring...at STOP position:
* it can make the motor to free run (open)
* or it can make the motor to break (short circuit)
Maybe in "free run" it passes the notch and starts again..
Hi
Can you tell me what should be the micros switch wiring so that it will be stopped after one round.
I have attached the block diagram of existing circuit. please suggest
I just recognized that your wuring diagram shows the microswitch NC and NO to be shorted. This makes no sense, it makes the switch useless, because the current is never stopped from flowing, either it runs through NC or NO, one of these paths is always closed.
Try to use NC only.
If it does not work: try to use NO only
* Does your motor draw so much current that it causes the supply voltage to droop?
* Does you motor create noise (glitches) on the supply rails?
Either of these can cause faults in a control circuit.
Try to use NC only.
I have used NO but again Motor does not stop when micro switch press.
NC didn't work
Try to use NC only.
I have attached an image of different motor which uses the exact circuit diagram (NO and NC short) which I have followed and it works fine completely but not mine.
My motor takes around 200mA Max.
Motor does not create noise
NC didn't work
In your diagram both motors are connected to NO and NC. Did you disconnect one motor , or did you just remove one or the other connectors on microswitch.
NC didn't work
I have changed the microswitch connections only
NC didn't work
I had one another motor which has different connections so I decided to changes its connection to make it exactly the other wine (White motor)
Try to use NC only.
I have main board which has motor control circuit and has row and column to control the row and column of the vending machine.
I have made changes in motor in two ways:
A. I have attached an image for circuit diagram
In this design I have some pros and cons
PROS: 1. It stops at its home position after one rotation
2. It detects row and column of the machine
CONS: 1. Sometime it does not stop at its home position or take more than 1 rotation
B. I have attached an image of other diagram
In this design also I have some pros and cons
PROS: 1. It stops perfectly at its home position after one rotation.
CONS: 1. It does not detect ROW
Please suggest What should I follow and what should I made changes in the circuit.
Test with the above option A with the following changes:
-Connect to NC contacts.
-Remove the 100 microfarad capacitor.
Connect to NC contacts means?
I have shorted NC NO contacts.
Actually I have another Motor which has same circuit and works completely fine with NO NC shorted.
So I decided to replicate my motor to that Motor but my motor does not work exactly same like another motor.
I have removed the capacitor but again facing the same issue.
[video]http://www.nls.net/mp/volks/schem/wiper.htm[/video][video]https://electronics.stackexchange.com/questions/395162/vending-machine-motor-and-switch-circuit[/video]
I see that the pcb on motor in your video is different than one in photo.
PCB on video and on photo is not different.
I have changed the circuit which is shown in video and my circuit diagram too which I already posted on this group.
