P10 DMD-2PANEL-CCS C-18F2520__why ended up each panel individually while scrolling
saramah
Member level 3
hI,
The structure I want to use is 64x16 matrix, ie TWO P10-panels side by side. For that the DRIVER and MAIN two file is attached.
It is working fine in SINGLE-Panel,
but when trying to SCROLL(Right-Left scroll) with 2-Panel, its moving separately(panel wise), not altogether with 2-panel as usual.
Upper Row of the Attached video is showing that problems, right panel's text not moving through the LEFT panel. Instead ended up individually as upper part of the vid.
tnx[video]https://drive.google.com/file/d/1zWcF_26cJeMwnxfGmoomULQlcuWRjWZJ/view?usp=sharing[/video]
The code is here contained 2 .txt file. one is main and another is driver
tnxView attachment main-n-driver-2panel.zip
