Results 1 to 4 of 4
    Advanced Member level 3
    Points: 5,455, Level: 17
    Jan 2012
    Italy
    951
    5,455
    17
    Common mode gain simulation for differential amplifier using balun
    Dear friends,
    So far one of our mentors, Panch told me about excellent source to simulate the fully differential amplifier using Balun, I am using now this instance and giving me good shorcut. One issue I have with simulating the common mode gain (ACM),
    attached you see the setup according to the source explanation
Name:	New Doc 5.jpg
    Under the AC simulation we probe the VOC which represent the ACM (because the input is 1 V).
    My question that generally ACM = VOD/VID where VID are two inphase signal, how this equation is achieved from the proposed setup ?
    to have a detail about the setup please read section 3.1 from the below document (suggested by Pancho)
    https://designers-guide.org/analysis/diff.pdf
    Thank you very much in advance
    Points: 51,877, Level: 55
    erikl's Avatar
    Sep 2008
    Germany
    8,090
    51,877
    55
    Re: Common mode gain simulation for differential amplifier using balun
    I think the second paragraph of 3.1 Gain in the a.m. PDF should read (only for the Balun nomenclature of your a.m. picture!):
    To measure the common-mode gain, set the AC magnitude on Vic to 1 V and on all other sources to 0. The common-mode voltage gain is then identical to the voltage at the c terminal of B1 and The common-to-differential-mode conversion is identical to the voltage at the d terminal of B1.
    Jan 2012
    Italy
    951
    5,455
    17
    Dear Erikl,
    Thank you for your reply
    I think I did two mistakes, first in my plot, the output balun should be Bo and the the input balun is B1.
    The second mistake is about the difinition of the Common mode gain in fully differential amplifier, I stated it as differential output voltage / common mode input ..... ACM=(VO1-VO)/Vic
    while it should be ACM= Voc/Vic = [(Vo1+Vo2)/2]/Vic
    isnt it ?
    Thank you again
    erikl's Avatar
    Sep 2008
    Germany
    8,090
    51,877
    55
    Quote Originally Posted by Junus2012 View Post
    ... first in my plot, the output balun should be Bo and the the input balun is B1.
    In order to stay consistent with Ken Kundert's Test Bench description, you should name the input balun Bi (i for input) and the output balun Bo (o for output).
    ... it should be ACM= Voc/Vic = [(Vo1+Vo2)/2]/Vic
    isnt it ?
    Yes, I think so!
