Results 1 to 6 of 6
    Member level 5
    Points: 1,138, Level: 7
    Jan 2016
    86
    1,138
    7
    Converting verilog code into a symbol during AMS simulation
    Dear all,
    I have a verilog code with input in[3:0] and output out[3:0]. When i try to create a symbol for it for ams simulation, it gives me only 2 pins. One pin for input, in<3:0> instead of 4 pins as in[3], in[2], in[1], in[0]. The other is for output, out<3:0> instead of 4 pins. I am really not sure of how to give the inputs to this? AM i missing out on something? Can some one help?
    Points: 17,492, Level: 32
    pancho_hideboo's Avatar
    Oct 2006
    Real Homeless
    2,689
    17,492
    32
    Re: Converting verilog code into a symbol during AMS simulation
    Simply they are bus pins.
    Member level 5
    Jan 2016
    86
    1,138
    7
    How will i be able to split the pins? As in, I would like to have 4 pins by name in[0], in[1], in[2], in[3] instead of one pin in[3:0].
    Oct 2006
    Real Homeless
    2,689
    17,492
    32
    Simply edit manually.
    Full Member level 5
    Points: 1,764, Level: 9
    Apr 2017
    263
    1,764
    9
    Member level 5
    Jan 2016
    86
    1,138
    7
    Thanks for the help,
    So i split the inputs while defining input output pins in the module. For example
    module inve(in[1], in[2], out[2], out[1]);
    This seems to work
