Results 1 to 6 of 6
17th September 2019, 08:40 #1
- Join Date
- Jan 2016
- Posts
- 86
- Helped
- 0 / 0
- Points
- 1,138
- Level
- 7
Converting verilog code into a symbol during AMS simulation
Dear all,
I have a verilog code with input in[3:0] and output out[3:0]. When i try to create a symbol for it for ams simulation, it gives me only 2 pins. One pin for input, in<3:0> instead of 4 pins as in[3], in[2], in[1], in[0]. The other is for output, out<3:0> instead of 4 pins. I am really not sure of how to give the inputs to this? AM i missing out on something? Can some one help?
Advertisement
17th September 2019, 14:41 #2
- Join Date
- Oct 2006
- Location
- Real Homeless
- Posts
- 2,684
- Helped
- 725 / 725
- Points
- 17,428
- Level
- 31
Re: Converting verilog code into a symbol during AMS simulation
Simply they are bus pins.
Advertisement
17th September 2019, 15:01 #3
- Join Date
- Jan 2016
- Posts
- 86
- Helped
- 0 / 0
- Points
- 1,138
- Level
- 7
How will i be able to split the pins? As in, I would like to have 4 pins by name in[0], in[1], in[2], in[3] instead of one pin in[3:0].
Advertisement
17th September 2019, 15:37 #4
- Join Date
- Oct 2006
- Location
- Real Homeless
- Posts
- 2,684
- Helped
- 725 / 725
- Points
- 17,428
- Level
- 31
Simply edit manually.
18th September 2019, 14:51 #5
- Join Date
- Apr 2017
- Posts
- 262
- Helped
- 6 / 6
- Points
- 1,732
- Level
- 9
Advertisement
19th September 2019, 14:00 #6
- Join Date
- Jan 2016
- Posts
- 86
- Helped
- 0 / 0
- Points
- 1,138
- Level
- 7
Thanks for the help,
So i split the inputs while defining input output pins in the module. For example
module inve(in[1], in[2], out[2], out[1]);
This seems to work
Please login
