Results 1 to 3 of 3
    Points: 32,986, Level: 44
    Sep 2008
    cambridge
    6,864
    32,986
    44
    IRS25752 IC has no pin 1 marker
    Hi
    I just bought two pieces of the IRS25752 IC from Farnell and its got no pin 1 marker.
    Do you know how i can tell which is pin1?
    There is lettering on top and i wonder if one is viewing this lettering from the right way up, then its on the left/right?
    (The lettering says "5ND1")
    I have viewed the chip surface from all angles and there is no marker for pin 1
    IRS25752
    https://www.infineon.com/dgdl/Infine...53567b388b2839
    Advanced Member level 2
    Points: 2,928, Level: 12
    Aug 2016
    511
    2,928
    12
    Re: IRS25752 IC has no pin 1 marker
    Let's see a picture of the IC.
    --Akanimo.
    Points: 39,762, Level: 48
    Mar 2008
    USA
    6,426
    39,762
    48
    The datasheet indicates to me that you are left to use
    the lot / date code on the top, or the mfr logo on the
    bottom, to orient yourself. See Pg 11.
