Results 1 to 3 of 3
    Member level 5
    Points: 1,077, Level: 7
    Jan 2016
    82
    1,077
    7
    AMS simulation of D-FF
    Hello all,
    I am unable to simulate D-flipflop properly in AMS. The input that i am giving is itself shown incorrect on the wave form window. I was able to simulate simple gates but find ing problems with D flip flop. Attaching the code and waveform.
    module DFF_VERI(D,clk,Q);
    input D; // Data input
    input clk; // clock input
    output reg Q; // output Q
    always @(posedge clk)
    begin
     Q = D;
    end
    endmodule
    Points: 260,224, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,441
    260,224
    100
    Re: AMS simulation of D-FF
    There's no clock signal fed to your circuit, respectively output is uninitialized..
    Confusingly you are providing a multi level ("electrical") signal to the D input which makes no sense for a D-FF.
    Points: 39,706, Level: 48
    Mar 2008
    USA
    6,413
    39,706
    48
    The module has no reset and no special-case initialization code,
    so there will be some problems getting an initial solution.
    Here's code for a well-used veriloga DFF from a CMOS standard
    cell library:
    Code Verilog - [expand]
    8
    9
    10
    11
    12
    13
    14
    15
    16
    17
    18
    19
    20
    21
    22
    23
    24
    25
    26
    // VerilogA for dffr
    // active-low reset, positive-edge clock
    `include "constants.h"
    `include "discipline.h"
    module dffr ( data, reset, clk, vdd, vss, q);
    input data,reset,clk,vdd,vss;
    output q;
    voltage data, reset, clk, vdd, vss, q;
    real vth, qx;
    integer logicd, logicr;
    analog begin
      vth=(V(vdd)+V(vss))*0.5;
      logicr = V(reset) > vth;
      @ (cross(V(clk) - vth,1)) logicd = V(data) > vth;
      logicd = logicd * logicr;
      qx=(logicd) ? V(vdd) : V(vss);
      V(q) <+ transition(qx,1.5n,200p,200p);
    end
    endmodule
    Last edited by BradtheRad; 17th September 2019 at 02:40. Reason: Added code formatted window
