Results 1 to 12 of 12
    Junior Member level 3
    Points: 200, Level: 2
    Apr 2019
    27
    200
    Gate Level Simulation
    Do we use .lib for gate level simulation of netlists?
    Advanced Member level 2
    Points: 2,928, Level: 12
    Aug 2016
    512
    2,928
    12
    Re: Gate Level Simulation
    Quote Originally Posted by fragnen View Post
    Gate level simulation of what netlist? Where? With what?
    You need to give details.
    --Akanimo.
    Apr 2019
    27
    200
    Quote Originally Posted by Akanimo View Post
    Are not gate level simulation always done on netlists?
    The post was raised for gate level simulation on netlists.
    Points: 17,097, Level: 31
    pancho_hideboo's Avatar
    Oct 2006
    Real Homeless
    2,628
    17,097
    31
    No one can understand what you mean.
    Express in detail with correct terminology.
    Do you mean Gate-Level-HDL which is synthesized from RTL-HDL ?
    Apr 2019
    27
    200
    Quote Originally Posted by pancho_hideboo View Post
    After rtls are synthesized using a synthesis tool like Design Compiler of Synopsys, we get a netlist. The simulation of this netlist is called gate level simulation. Is it clear now?
    Points: 8,693, Level: 22
    Apr 2016
    1,826
    8,693
    22
    Yes. You need an SDF file to be simulated with the netlist. That's all.
    Really, I am not Sam.
  7. #7
    Oct 2006
    Real Homeless
    2,628
    17,097
    31
    we get a netlist.
    It is Gate-Level-HDL.
    Quote Originally Posted by ThisIsNotSam View Post
    I don’t think he reaches to SDF annotation.
    Simply his purpose requires standard cell library or technology library.
  8. #8
    Apr 2016
    1,826
    8,693
    22
    at a bare minimum, a verilog file of the standard cell library is needed. this should be combined with an SDF, otherwise you get some timing model that is not realistics like a unit delay model (ie, every cells takes 1 time unit to compute its output).
  9. #9
    Apr 2019
    27
    200
    Can a .lib files of a standard cells be used instead of a verilog models of standard cell for gate level simulation?
  10. #10
    Apr 2016
    1,826
    8,693
    22
    in theory, yes. lib files do contain the equation of the cell. in practice, no, no simulator that I know of will take a .lib as input
  11. #11
    Apr 2019
    27
    200
    But the equation in .lib may not be similar to the model file. For example if a D-fliplop is taken its behavioural code is understood as a D-flipflop but the equation of it does not reflect the behaviour of a D-flipflop. A LEC tool can read those equations of cells in a .lib if I am not doing any mistake.
  12. #12
    Apr 2016
    1,826
    8,693
    22
    what do you want me to say? if you try to hack a solution, you get as far as the hack takes you. there are standard ways of doing things, stick to those and you will not have to worry about model incoherence.
