Results 1 to 4 of 4
    Full Member level 4
    Points: 1,228, Level: 7
    Jan 2018
    201
    1,228
    7
    What happens to output power and 3 BW in this circuit
    Hi, I calcaulated L and C values for a butterworth filter, to get 3 dB BW of 50 GHz and attenuation of 6 dB at 60 GHz. Next, I gave 10 dBm input power and I got the expected result.
    Again I took two sections of the same T network and gave input at different points as shown in figure, I am not sure what is its expected behavior. can someone explain how this circuit should work? Thanks
    Points: 17,003, Level: 31
    pancho_hideboo's Avatar
    Oct 2006
    Real Homeless
    2,613
    17,003
    31
    Re: What happens to output power and 3 BW in this circuit
    Quote Originally Posted by circuitslave View Post
    Why do you set three ports.
    Where is driving point ?
    What do you expect ?
    Full Member level 4
    Jan 2018
    201
    1,228
    7
    Quote Originally Posted by circuitking View Post
    The ports connected to the capacitors providing input power of 10 dBm each (loaded LC ladder section). I kept ports to find the ZP and SP at those points. I expect to see more output power at the last port(Port 3 in the figure). But I am not sure its working technicalities and analytical equations yet.
    Oct 2006
    Real Homeless
    2,613
    17,003
    31
    Can you understand filter ladder circuit ?
    Learn very basic things before EDA Tool Play.
