Results 1 to 3 of 3
    Newbie level 1
    Points: 14, Level: 1
    Sep 2019
    14
    PS with LM76003 for variable volatage and variable current design?
    LM76003 is 3.5A Synchronous Step-Down Voltage Converter.
    I want to use it for design power suplly with variable output voltage 1-45 with with current range near 0 to 3,5A.
    My operating conditions:
    Input vopltage 50V.
    Switching frequency 350-500kHz
    Output voltage 1-42V
    Output current tens of mA - 3,5A
    And I have a few questions.,
    1.Choice of output coil and capacitors.
    Output coil.
    Due to the large output current range I oversized it and even at a high switching frequency I consider 47uH 4.5A
    2. Output capacitors.
    I thing SMD ceramic 2x 47uF 100V size 1812 + 8x 10uF 100V size 1210 = 147uF in SMD ceramics, plus any small 100nF/330nF.
    It is recommended to use more capacity in ceramics or add aluminium for example 470uF LXZ ?
    Points: 52,908, Level: 56
    Apr 2011
    Minneapolis, Minnesota, USA
    12,945
    52,908
    56
    Re: PS with LM76003 for variable volatage and variable current design?
    When you draw high power your output capacitors have to carry 1 or 2 Amperes per cycle. That's thousands of times per second. It may be all right to have a gang of several surface mount capacitors as listed in your specs.
    If you attach very large uF, then it may draw large surge current at power-up.
    Points: 11,163, Level: 25
    Aug 2015
    1,814
    11,163
    25
    lots of input capacitance is necessary to make it stable ...
