Results 1 to 4 of 4
    Full Member level 4
    Points: 1,911, Level: 10
    Sep 2014
    india
    225
    1,911
    10
    Multiplexing problem in my 8051 clock project.
    Dear All,
    I am making a clock of dual display one 4 digit 7 segment display and Lcd(16x2) by using 89s52.both should show time(as my application).I am using multiplexing method in displaying data on led display.Lcd display running successfully but led display shows on-off continously.Here is my code.
    #include
    sbit set=P1^0;
    sbit mov=P1^1;
    sbit inc=P1^2;
    sbit dec=P1^3;
    sbit rly=P1^4;
    sbit digi1=P1^5;//3rd e5
    sbit digi4=P2^3;//4th	e6
    sbit blink=P2^1;
    sbit bus=P3^7;
    sbit ind=P3^6;
    sbit digi3=P1^7;//1st e4
    sbit digi2=P1^6;//2nd e3
    sbit SDA=P2^6;
    sbit SCL=P2^7;
    bit d;
    bit e;
    bit f;
    bit nxt;
    bit nxta;
    unsigned char dec_hex(unsigned char tt)
    if(tt>59)
    tt+=36;
    else if(tt>49)
    tt+=30;
    else if(tt>39)
    tt+=24;
    else if(tt>29)
    tt+=18;
    else if(tt>19)
    tt+=12;
    else if(tt>9)
    tt+=6;
    return(tt);
    display_digit();
    void all_disp();
    void time_set();
    void alarm_set();
    void set_date();
    void blink_on();
    	void buzzer();
    void no_op();
    void setdisp_ampm();
    	 void alarm_setsat();
    unsigned int zt;
    unsigned char led_data;
    void alarm_bell_HI();
    void alarm_bell_LOW();
    void display_day();
    void puls();
    void no_puls();
    #define First_Line 0x80
    #define Second_Line 0xc0
    #define Curser_On 0x0f
    #define Curser_Off 0x0c
    #define Clear_Display 0x01
    #define idle f==1
    #define no_idle f==0
    #define Data_Port P0
    sbit Lcd_rs = P2^0;
    //sbit Lcd_rw = P2^1;
    sbit Lcd_en = P2^2;
    sbit sda_rtc =P2^5;
    sbit scl_rtc =P2^4;
    /*sbit Lcd_rs = P3^5;
    sbit Lcd_rw = P3^6;
    sbit Lcd_en = P3^7; */
    void Lcd8_Init();
    void Lcd8_Command(unsigned char);
    void Lcd8_Write(unsigned char,unsigned char);
    void Lcd8_Display(unsigned char,const unsigned char*,unsigned int);
    void Lcd8_decimal2(unsigned char,unsigned char val);
    void Delay(unsigned int);
    void del();
    void hour_mode();
    void set_mod1();
    void set_mod2();
    unsigned char LB,SB;
    void Seg8_decimal2(min);
    void Led8decimal2(hour);
    unsigned char num;
    void EEPROM_WriteByte(unsigned char eeprom_Address, unsigned char eeprom_Data);
    unsigned char EEPROM_ReadByte(unsigned char eeprom_Address);
    void I2C_Start();
    void I2C_Stop(void);
    void I2C_Ack();
    void I2C_Write(unsigned char dat);
    unsigned char I2C_Read();
     #define EEPROM_ID 0xa0
    void delay_ms(unsigned int ms_count);
    void I2C_NoAck();
    void I2C_Clock();
    void delay_us(unsigned int us_count);
    void msdelay(unsigned int value);
    void emerg_bell();
    void display_ampm1();
    void display_ampm2();
    //unsigned char number[]="1,2,3,4";
    #define DS1307_ID 0xD0
    #define SEC 0x00
    #define MIN 0x01
    #define HOUR 0x02
    #define DAY 0x03
    #define DATE 0x04
    #define MONTH 0x05
    #define YEAR 0x06
    #define ctrl 0x07
    #define FRIDAY 0x06
    #define SATURDAY 0x00
    #define SUNDAY 0x01
    DS1307_get(unsigned char);
    void DS1307_settime(unsigned char, unsigned char, unsigned char);
    void DS1307_setdate(unsigned char, unsigned char, unsigned char,unsigned char);
    Send2lcd(unsigned char);
    void Rtc_Write(unsigned char,unsigned char);
    Rtc_Read(unsigned char);
    void Rtc_rd_wr_sub();
    void Rtc_Init();
    void Rtc_Start();
    void Rtc_Tx();
    void Rtc_Rx();
    void Rtc_Stop();
    void Rtc_Ack();
    void disp();
    void disp_time();
    void display_ampm();
    void dispampm();
    void set_ampm();
    void set_mod();
    void alarm_chk1();
    void alarm_chk2();
    void alarm_chk3();
    void alarm_chk4();
    void all_alrmset();
     void all_alrmsetsat();
    void friday_chk();
    void regular_chk();
    	void saturday_chk();
    void idle_chk();
    void no_idle_chk();
    void key_lock2();
    unsigned int Rtc_add_wr,Rtc_add_rd;
    unsigned char d_rtc,datain_rtc,in_rtc,temp_rtc,dat_rtc,flag_rtc;
    unsigned char i,j,a[10],cur=0,cur1=0,cur2=0,cur3=0,cur4=0;
    unsigned char dati,sec,hour,min,date,day,month,year,mode=0,clk_a  mpm,sec1,hour1,min1,sec2,hour2,min2,hh,mm,ss,dd,mn  ,yy,ahour,amin,ampm,asec,amin1,ahour1,ampm1;
    unsigned char count[8]={0x82,0x85,0x8a,0x8d,0xc2,0xc5,0xcb,0xcd};   ///0x8a changed
    code unsigned char memo[66]={0x01,0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09,0x1  0,0x11,0x12,0x13,0x14,0x15,0x16,0x17,0x18,0x19,0x2  0,0x21,0x22,0x23,0x24,0x25,0x26,0x27,0x28,0x29,0x3  0,0x31,0x32,0x33,0x34,0x35,0x36,0x37,0x38,0x2a,0x2  b,0x2c,0x2d,0x2e,0x2f,0x3a,0x3b,0x3c,0x3d,0x3e,0x3  f,0x1a,0x1b,0x1c,0x1d,0x1e,0x1f,0xa,0xb,0xc,0xd,0x  e,0xf,0x39,0x40,0x4a,0x4b};
    code unsigned char memo1[66]={0x42,0x43,0x44,0x45,0x46,0x47,0x48,0x49,0x50,0x5  1,0x52,0x53,0x54,0x55,0x56,0x57,0x58,0x59,0x60,0x6  1,0x62,0x63,0x64,0x65,0x66,0x67,0x68,0x69,0x70,0x7  1,0x72,0x73,0x74,0x75,0x76,0x77,0x78,0x79,0x5a,0x5  b,0x5c,0x5d,0x5e,0x5f,0x6a,0x6b,0x6c,0x6d,0x6e,0x6  f,0x7a,0x7b,0x7c,0x7d,0x7e,0x7f,0x8a,0x8b,0x8c,0x8  d,0x8e,0x8f,0x9a,0x9b,0x9c,0x9d};
    unsigned char count1[6]={0x86,0x89,0x8b,0xc6,0xc9,0xcb};
    unsigned char count2[2]={0x8b,0xcb};
    unsigned char rly_hex(unsigned char tt)
    if(tt>59)
    tt+=36;
    else if(tt>49)
    tt+=30;
    else if(tt>39)
    tt+=24;
    else if(tt>29)
    tt+=18;
    else if(tt>19)
    tt+=12;
    else if(tt>9)
    tt+=6;
    return(tt);
    void all_disp()
    sec = DS1307_get(SEC);
    min = DS1307_get(MIN);
    hour = DS1307_get(HOUR);
    dispampm();
    setdisp_ampm();
    hour=hour& 0x1f;
    display_ampm();
    date = DS1307_get(DATE);
    day = DS1307_get(DAY);
    month = DS1307_get(MONTH);
    year = DS1307_get(YEAR);
    sec=Send2lcd(sec);
    min=Send2lcd(min);
    hour=Send2lcd(hour);
    day=Send2lcd(day);
    date=Send2lcd(date);
    year=Send2lcd(year);
    month=Send2lcd(month);
    //P3=day;
    Lcd8_decimal2(0xc6,hour);
    Lcd8_Write(0xc8,'.');
    Lcd8_decimal2(0xc9,min);
    Lcd8_Write(0xcb,'.');
    Lcd8_decimal2(0xcc,sec);
    	Lcd8_decimal2(0x82,date);
    Lcd8_Write(0x84,'-');
    Lcd8_decimal2(0x85,month);
    Lcd8_Write(0x87,'-');
    Lcd8_Display(0x88,"20 ",2);
    Lcd8_decimal2(0x8a,year);
    //Lcd8_decimal2(0x8d,day);
    Seg8_decimal2(min);//..................................................  ..................................................  ...............
    Led8decimal2(hour);//..................................................  .................................................
    void main()
    nxt=0;
    rly=0;
    dati=0x00;
    Lcd8_Init();
    Lcd8_Display(0x82,"ZAKARIYA ",8);
    	Lcd8_Display(0xc3,"Technologies ",12);
    Delay(65000);
    Delay(65000);
    Lcd8_Command(0x01);
    Rtc_Init();
    	//puls();
    //DS1307_setdate(0x04,0x11,0x11);
    //DS1307_settime(0x16,0x00,0x00);
    while(1)
    	//P1=EEPROM_ReadByte(memo[1]);
    	dati++;
    all_disp();
    	Rtc_Start();
    Rtc_Write(0x07,0x10);
    Rtc_Stop(); /* Stop i2c bus */
    //disp();
    	display_day();
    	//no_idle_chk();if(no_idle) goto straight;  //No alarm betwen 8pm to 6am
    //idle_chk();if(idle) goto jump;  //No alarm betwen 8pm to 6am
    //if(day==SATURDAY) goto jump;
    if(day==0x01) goto jump;
    //if(day==FRIDAY)
    //friday_chk();
    //else
    	if(day==0x07)
    	saturday_chk();
    	else
    straight:
    regular_chk();
    jump:
    	if(!set)
    		key_lock2();  ///show as keypad locked(when press set/inc/dec)
     if(!inc)
     if(!dec)
     if(!dec)
     alarm_bell_HI();
      if(!set)
     alarm_bell_LOW();
    if(mov==0)
    Delay(65000);
    Delay(65000);
    Delay(65000);
    if(mov==0)
    		Lcd8_Command(0x01);
    	Lcd8_Display(0xc4,"Unlocked ",8);
    	Delay(65000);
    time_set();
    	cur2=0;
    	cur4=0;
    			Lcd8_Command(0x01);
    		Lcd8_Command(0x0c);
    	Lcd8_Display(0x82,"REGULAR ",7);
    	Lcd8_Display(0xC4,"SCHEDULE ",8);
    		Delay(65000);
    		Delay(65000);
    all_alrmset();
    	Lcd8_Command(0x01);
    Lcd8_Display(0x82,"SATURDAY",8);
    	Delay(65000);
    	Delay(65000);
    all_alrmsetsat();
    set_date();
    if(dati==0x03)
    blink=~blink;
    dati=0x00;
    void dispampm()
    	if(hour==0x00)
    		 d=0;
    clk_ampm=0;
    Rtc_Start();
    Rtc_Write(0x02,0x40);
    		if(hour==0x01)
    				 d=0;
    clk_ampm=0;
    Rtc_Start();
    Rtc_Write(0x02,0x41);
    			if(hour==0x02)
    				 d=0;
    clk_ampm=0;
    Rtc_Start();
    Rtc_Write(0x02,0x42);
    		if(hour==0x03)
    				 d=0;
    clk_ampm=0;
    Rtc_Start();
    Rtc_Write(0x02,0x43);
    		if(hour==0x04)
    				 d=0;
    clk_ampm=0;
    Rtc_Start();
    Rtc_Write(0x02,0x44);
    		if(hour==0x05)
    				 d=0;
    clk_ampm=0;
    Rtc_Start();
    Rtc_Write(0x02,0x45);
    		if(hour==0x06)
    				 d=0;
    clk_ampm=0;
    Rtc_Start();
    Rtc_Write(0x02,0x46);
    		if(hour==0x07)
    				 d=0;
    clk_ampm=0;
    Rtc_Start();
    Rtc_Write(0x02,0x47);
    		if(hour==0x08)
    				 d=0;
    clk_ampm=0;
    Rtc_Start();
    Rtc_Write(0x02,0x48);
    		if(hour==0x09)
    				 d=0;
    clk_ampm=0;
    Rtc_Start();
    Rtc_Write(0x02,0x49);
    		if(hour==0x10)
    				 d=0;
    clk_ampm=0;
    Rtc_Start();
    Rtc_Write(0x02,0x4a);
    		if(hour==0x11)
    				 d=0;
    clk_ampm=0;
    Rtc_Start();
    Rtc_Write(0x02,0x4b);
    		if(hour==0x12)
    				 d=1;
    clk_ampm=1;
    Rtc_Start();
    Rtc_Write(0x02,0x72);
    		if(hour==0x13)
    						 d=1;
    clk_ampm=1;
    Rtc_Start();
    Rtc_Write(0x02,0x61);
    		if(hour==0x14)
    						 d=1;
    clk_ampm=1;
    Rtc_Start();
    Rtc_Write(0x02,0x62);
    		if(hour==0x15)
    						 d=1;
    clk_ampm=1;
    Rtc_Start();
    Rtc_Write(0x02,0x63);
    		if(hour==0x16)
    						 d=1;
    clk_ampm=1;
    Rtc_Start();
    Rtc_Write(0x02,0x64);
    		if(hour==0x17)
    						 d=1;
    clk_ampm=1;
    Rtc_Start();
    Rtc_Write(0x02,0x65);
    		if(hour==0x18)
    						 d=1;
    clk_ampm=1;
    Rtc_Start();
    Rtc_Write(0x02,0x66);
    		if(hour==0x19)
    						 d=1;
    clk_ampm=1;
    Rtc_Start();
    Rtc_Write(0x02,0x67);
    		if(hour==0x20)
    						 d=1;
    clk_ampm=1;
    Rtc_Start();
    Rtc_Write(0x02,0x68);
    		if(hour==0x21)
    						 d=1;
    clk_ampm=1;
    Rtc_Start();
    Rtc_Write(0x02,0x69);
    		if(hour==0x22)
    						 d=1;
    clk_ampm=1;
    Rtc_Start();
    Rtc_Write(0x02,0x6a);
    		if(hour==0x23)
    						 d=1;
    clk_ampm=1;
    Rtc_Start();
    Rtc_Write(0x02,0x6b);
    void key_lock2()
    	Lcd8_Command(0x01);
    	Lcd8_Display(0xc1,"Keypad locked ",13);
    Delay(65000);
    Lcd8_Command(0x01);
    void idle_chk()
    if(hour==7)
    if(d==1)
    	f=1;
    if(hour==8)
    	if(d==1)
    		f=1;
    if(hour==9)
    	if(d==1)
    		f=1;
    if(hour==10)
    	if(d==1)
    		f=1;
    if(hour==11)
    	if(d==1)
    	f=1;
    if(hour==12)
    	if(d==0)
    	f=1;
    if(hour==1)
    	if(d==0)
    	f=1;
    if(hour==2)
    	if(d==0)
    	f=1;
    if(hour==3)
    	if(d==0)
    	f=1;
    if(hour==4)
    	if(d==0)
    	f=1;
    if(hour==5)
    	if(d==0)
    	f=1;
    if(hour==6)
    	if(d==0)
    	f=1;
    void no_idle_chk()
    if(hour==7)
    if(d==0)
    	f=0;
    if(hour==8)
    	if(d==0)
    		f=0;
    if(hour==9)
    	if(d==0)
    		f=0;
    if(hour==10)
    	if(d==0)
    		f=0;
    if(hour==11)
    	if(d==0)
    	f=0;
    if(hour==12)
    	if(d==1)
    	f=0;
    if(hour==1)
    	if(d==1)
    	f=0;
    if(hour==2)
    	if(d==1)
    	f=0;
    if(hour==3)
    	if(d==1)
    	f=0;
    if(hour==4)
    	if(d==1)
    	f=0;
    if(hour==5)
    	if(d==1)
    	f=0;
    if(hour==6)
    	if(d==1)
    	f=0;
     void all_alrmset(void)
    	 nxt=0;
    	 up:alarm_set();
    	 //alarm_setsat();
    	 if(nxt==0) goto up;
      void all_alrmsetsat(void)
    	 nxta=0;
    	 up:alarm_setsat();
    	 if(nxta==0) goto up;
     void friday_chk()
     void regular_chk()
     alarm_chk1();
     alarm_chk2();
      void saturday_chk()
     alarm_chk3();
     alarm_chk4();
     void setdisp_ampm()
    	 	if(hour==0x52)
    	  d=0;
    		clk_ampm=00;
    		if(hour==0x41)
    	  d=0;
    		clk_ampm=00;
        if(hour==0x42)
    	  d=0;
    		clk_ampm=00;
        if(hour==0x43)
    	  d=0;
    		clk_ampm=00;
    		if(hour==0x44)
    	  d=0;
    		clk_ampm=00;
        if(hour==0x45)
    	  d=0;
    		clk_ampm=00;
        if(hour==0x46)
    	  d=0;
    		clk_ampm=00;
        if(hour==0x47)
    	  d=0;
    		clk_ampm=00;
        if(hour==0x48)
    	  d=0;
    		clk_ampm=00;
        if(hour==0x49)
    	  d=0;
    		clk_ampm=00;
        if(hour==0x4a)
    	  d=0;
    		clk_ampm=00;
        if(hour==0x4b)
    	  d=0;
    		clk_ampm=00;
    	if(hour==0x72)
        d=1;
    		clk_ampm=01;
      if(hour==0x61)
        d=1;
    	  clk_ampm=01;
      if(hour==0x62)
        d=1;
    		clk_ampm=01;
      if(hour==0x63)
        d=1;
    		clk_ampm=01;
      if(hour==0x64)
        d=1;
    		clk_ampm=01;
      if(hour==0x65)
        d=1;
    		clk_ampm=01;
      if(hour==0x66)
        d=1;
    		clk_ampm=01;
      if(hour==0x67)
        d=1;
    		clk_ampm=01;
      if(hour==0x68)
        d=1;
    		clk_ampm=01;
      if(hour==0x69)
        d=1;
    		clk_ampm=01;
      if(hour==0x6a)
        d=1;
    		clk_ampm=01;
      if(hour==0x6b)
        d=1;
    		clk_ampm=01;
    void disp_time()
    	hour=hour& 0x1f;
    sec=Send2lcd(sec);
    min=Send2lcd(min);
    	Lcd8_decimal2(0xc2,hour);
    Lcd8_Write(0xc4,'.');
    Lcd8_decimal2(0xc5,min);
    Lcd8_Write(0xc7,'.');
    Lcd8_decimal2(0xc8,sec);
    set_ampm();
    Seg8_decimal2(min);
    Led8decimal2(hour);
    void display_ampm()
     if(d==0)
      Lcd8_Display(0xce,"AM ",2);/////////////////////////////////////////////////////////changed
     if(d==1)
    	Lcd8_Display(0xce,"PM ",2);/////////////////////////////////////////////////////////changed
     if(d==0)
      Lcd8_Display(0x8b,"AM ",2);/////////////////////////////////////////////////////////changed
     if(d==1)
    	Lcd8_Display(0x8b,"PM ",2);/////////////////////////////////////////////////////////changed
     if(d==0)
      Lcd8_Display(0xcb,"AM ",2);/////////////////////////////////////////////////////////changed
     if(d==1)
    	Lcd8_Display(0xcb,"PM ",2);/////////////////////////////////////////////////////////changed
    void set_ampm()
    	 if(d==0)
    	 clk_ampm=00;
     if(d==1)
    clk_ampm=01;
    void emerg_bell()
    void no_op()
    void hour_mode()
    	if(hour>12)
    		hour=hour-12;
    void puls()
    	Rtc_Start();
    Rtc_Write(0x07,0x10); /* Write date on RAM address 04H */
    void no_puls()
    Rtc_Start();
    Rtc_Write(0x07,0x00); /* Write date on RAM address 04H */
    void display_day()
     if(day==0x01)
    Lcd8_Display(0xc1,"SUN    ",3);
     if(day==0x02)
    Lcd8_Display(0xc1,"MON    ",3);
     if(day==0x03)
    Lcd8_Display(0xc1,"TUE   ",3);
     if(day==0x04)
    Lcd8_Display(0xc1,"WED ",3);
     if(day==0x05)
    Lcd8_Display(0xc1,"THU  ",3);
     if(day==0x06)
    Lcd8_Display(0xc1,"FRI    ",3);
     if(day==0x07)
    Lcd8_Display(0xc1,"SAT  ",3);
    void set_date()
    	blink_on();
    Lcd8_Command(0x01);
    all_disp();
    cur=0;
    while(set)
    	Lcd8_Command(0x0f);
    Lcd8_Command(count[cur]);
    if(mov==0)
    while(!mov);
    cur++;
    			blink_on();
    if(cur==4)
    cur=0;
    else if(count[cur]==0x82)
    if(inc==0)
    while(inc==0);
    date++;
    blink_on();
    Lcd8_decimal2(count[cur],date);
    if(date>31)
    date=0;
    else if(dec==0)
    while(!dec);
    date--;
    blink_on();
    if(date==0xff)
    date=99;
    else if(count[cur]==0x85)
    if(inc==0)
    while(inc==0);
    month++;
    	blink_on();
    Lcd8_decimal2(count[cur],month);
    if(month>12)
    month=0;
    else if(dec==0)
    while(!dec);
    month--;
    	blink_on();
    if(month==0xff)
    month=99;
    else if(count[cur]==0x8a)
    if(inc==0)
    while(!inc);
    year++;
    	blink_on();
    	Lcd8_decimal2(count[cur],year);
    if(year>99)
    year=0;
    else if(dec==0)
    while(!dec);
    year--;
    	blink_on();
    if(year==0xff)
    year=99;
    else if(count[cur]==0x8d)
    if(inc==0)
    while(!inc);
    day++;
    	blink_on();
     //Lcd8_Command(0x01);
    	display_day();
    	Lcd8_decimal2(count[cur],day);
    if(day>6)
    day=0;
    else if(dec==0)
    while(!dec);
    day--;
    	blink_on();
    		display_day();
    if(day==0xff)
    day=7;
    dd=dec_hex(date);
    mn=dec_hex(month);
    yy=dec_hex(year);
    day=dec_hex(day);
    DS1307_setdate(dd,mn,yy,day);
    Lcd8_Command(0x0c);
    puls();
    void blink_on()
    blink=0;
      Delay(6500);
    blink=1;
    void set_mod()
    if(mode==1)
    d=0;
    clk_ampm=00;
    if(mode==2)
    d=1;
    clk_ampm=01;
    void set_mod1()
    if(mode==1)
    d=0;
    		//hour=hour-12;
    if(mode==2)
    	d=1;
    	//hour=hour+12;
    void set_mod2()
    if(mode==1)
    d=0;
    		//hour=hour-12;
    if(mode==2)
    	d=1;
    	//hour=hour+12;
    	void time_set()
    	blink_on();
     Lcd8_Command(Curser_On);
     Lcd8_Command(0x01);
     Lcd8_Display(0x84,"Set Time",8);
    disp_time();
    cur=4;
    while(set)
    		Lcd8_Command(0x0f);
    if(mov==0)
    while(!mov);
    cur++;
    blink_on();
    if(cur==7)
    cur=4;
    else if(count[cur]==0xc2)
    if(inc==0)
    while(inc==0);
    hour++;
    		blink_on();
    	Led8decimal2(hour);
    if(hour>12)
    hour=0;
    else if(dec==0)
    while(!dec);
    hour--;
    		blink_on();
    	Led8decimal2(hour);
    if(hour==0)
    hour=12;
    else if(count[cur]==0xc5)
    if(inc==0)
    while(inc==0);
    min++;
    		blink_on();
    Seg8_decimal2(min);
    if(min>=60)
    min=0;
    else if(dec==0)
    while(!dec);
    min--;
    		blink_on();
    	Seg8_decimal2(min);
    if(min==0xff)
    min=31;
    else if(count[cur]==0xcb)
    if(inc==0)
    while(!inc);
    mode++;
    set_mod();
    Delay(6500);
    blink_on();
    //display_ampm();
    if(mode>1)
    mode=0;
    hh=rly_hex(hour);
    mm=rly_hex(min);
    if(d==1)
    	hh= hh | 0x60;
    if(d==0)
    	hh= hh | 0x40;
    DS1307_settime(hh,mm,ss);
    	void buzzer()
    	//e4=0;
    	//e3=0;
    //P3=0xff;
    //e4=1;
    //e3=1;
    		//  Delay(6500);
    //Led8decimal2(hour);
    void alarm_setsat()
    	no_puls();
    	cur4++;
     ahour=EEPROM_ReadByte(memo1[cur4]);
      cur4++;
     amin=EEPROM_ReadByte(memo1[cur4]);
    	cur4++;
    	 ampm=EEPROM_ReadByte(memo1[cur4]);
    	cur4++;
    ahour1=EEPROM_ReadByte(memo1[cur4]);
    	  cur4++;
    amin1=EEPROM_ReadByte(memo1[cur4]);
    		cur4++;
    ampm1=EEPROM_ReadByte(memo1[cur4]);
    Delay(10000);
    	blink_on();
    	Lcd8_Command(Curser_Off);
    	Lcd8_Command(0x0f);
      Lcd8_Command(0x01);
    	Lcd8_Display(0x88,":",1);
      	Lcd8_Display(0xc8,":",1);
    		if(cur4<25)
      Lcd8_Display(0x82,"LB)",3);
    	Lcd8_decimal2(0x86,ahour);
      Lcd8_decimal2(0x89,amin);
    	Lcd8_decimal2(0x8b,ampm);
    if(ampm==0)
    	d=0;
    	display_ampm1();
    if(ampm==1)
    	d=1;
    	display_ampm1();
      Lcd8_Display(0xc2,"LB)",3);
      Lcd8_decimal2(0xc6,ahour1);
      Lcd8_decimal2(0xc9,amin1);
    	Lcd8_decimal2(0xcb,ampm1);
    if(ampm1==0)
    	d=0;
    	display_ampm2();
    if(ampm1==1)
    	d=1;
    	display_ampm2();
    else
      Lcd8_Display(0x82,"SB)",3);
    if(ampm==0)
    	d=0;
    	display_ampm1();
    if(ampm==1)
    	d=1;
    	display_ampm1();
      Lcd8_Display(0xc2,"SB)",3);
    if(ampm1==0)
    	d=0;
    	display_ampm2();
    if(ampm1==1)
    	d=1;
    	display_ampm2();
    cur1=0;
    while(set)
    Lcd8_Command(0x0f);
    Lcd8_Command(count1[cur1]);
    if(mov==0)
    while(!mov);
    cur1++;
    if(cur1==6)
    cur1=0;
    else if(count1[cur1]==0x86)			                    ///1st line of lcd
    if(inc==0)
    while(inc==0);
    ahour++;
    	blink_on();
    if(ahour>=13)
    ahour=0;
    Lcd8_decimal2(count1[cur1],ahour);
    else if(dec==0)
    while(!dec);
    ahour--;
    	blink_on();
    if(ahour==0)
    ahour=12;
    else if(count1[cur1]==0x89)
    if(inc==0)
    while(inc==0);
    amin++;
    	blink_on();
    if(amin>=60)
    amin=0;
    Lcd8_decimal2(count1[cur1],amin);
    else if(dec==0)
    while(!dec);
    amin--;
    		blink_on();
    if(amin==0)
    amin=59;
    else if(count1[cur1]==0x8b)
    if(inc==0)
    while(inc==0);
    ampm=0;
    	d=0;
    display_ampm1();
    	blink_on();
    if(ampm>1)
    ampm=0;
    //Lcd8_decimal2(count1[cur1],ampm);
    else if(dec==0)
    while(!dec);
    ampm=1;
    	d=1;
    display_ampm1();
    		blink_on();
    else if(count1[cur1]==0xc6)
    if(inc==0)
    while(inc==0);
    ahour1++;
    	blink_on();
    if(ahour1>=13)
    ahour1=0;
    Lcd8_decimal2(count1[cur1],ahour1);
    else if(dec==0)
    while(!dec);
    ahour1--;
    	blink_on();
    if(ahour1==0)
    ahour1=12;
    else if(count1[cur1]==0xc9)
    if(inc==0)
    while(inc==0);
    amin1++;
    	blink_on();
    if(amin1>=60)
    amin1=0;
    Lcd8_decimal2(count1[cur1],amin1);
    else if(dec==0)
    while(!dec);
    amin1--;
    	blink_on();
    if(amin1==0)
    amin1=60;
    else if(count1[cur1]==0xcb)
    if(inc==0)
    while(inc==0);
    ampm1=0;
    	d=0;
    display_ampm2();
    	blink_on();
    //Lcd8_decimal2(count1[cur1],ampm1);
    else if(dec==0)
    while(!dec);
    ampm1=1;
    	d=1;
    	display_ampm2();
    	blink_on();
    Lcd8_Command(0x0c);
    //Delay(65000);Delay(65000);
    cur4--;
    cur4--;
    cur4--;
    cur4--;
    cur4--;
     EEPROM_WriteByte(memo1[cur4], ahour);
    cur4++;
     EEPROM_WriteByte(memo1[cur4], amin);
    cur4++;
     EEPROM_WriteByte(memo1[cur4], ampm);
    cur4++;
     EEPROM_WriteByte(memo1[cur4], ahour1);
    cur4++;
     EEPROM_WriteByte(memo1[cur4], amin1);
     cur4++;
     EEPROM_WriteByte(memo1[cur4], ampm1);
     Lcd8_Command(0x01);
    if(cur4==66)
    	nxta=1;
    void alarm_set()
    	no_puls();
    	cur2++;
     ahour=EEPROM_ReadByte(memo[cur2]);
      cur2++;
     amin=EEPROM_ReadByte(memo[cur2]);
    	cur2++;
    	 ampm=EEPROM_ReadByte(memo[cur2]);
    	cur2++;
    ahour1=EEPROM_ReadByte(memo[cur2]);
    	  cur2++;
    amin1=EEPROM_ReadByte(memo[cur2]);
    		cur2++;
    ampm1=EEPROM_ReadByte(memo[cur2]);
    Delay(10000);
    	blink_on();
    	Lcd8_Command(0x0f);
      Lcd8_Command(0x01);
    		if(cur2<25)
    if(ampm==0)
    	d=0;
    	display_ampm1();
    if(ampm==1)
    	d=1;
    	display_ampm1();
    if(ampm1==0)
    	d=0;
    	display_ampm2();
    if(ampm1==1)
    	d=1;
    	display_ampm2();
    else
    if(ampm==0)
    	d=0;
    	display_ampm1();
    if(ampm==1)
    	d=1;
    	display_ampm1();
    if(ampm1==0)
    	d=0;
    	display_ampm2();
    if(ampm1==1)
    	d=1;
    	display_ampm2();
    cur1=0;
    while(set)
    Lcd8_Command(0x0f);
    if(mov==0)
    while(!mov);
    cur1++;
    if(cur1==6)
    cur1=0;
    if(inc==0)
    while(inc==0);
    ahour++;
    	blink_on();
    if(ahour>=13)
    ahour=0;
    else if(dec==0)
    while(!dec);
    ahour--;
    	blink_on();
    if(ahour==0)
    ahour=12;
    if(inc==0)
    while(inc==0);
    amin++;
    	blink_on();
    if(amin>=60)
    amin=0;
    else if(dec==0)
    while(!dec);
    amin--;
    		blink_on();
    if(amin==0)
    amin=59;
    if(inc==0)
    while(inc==0);
    ampm=0;
    	d=0;
    display_ampm1();
    	blink_on();
    if(ampm>1)
    ampm=0;
    else if(dec==0)
    while(!dec);
    ampm=1;
    	d=1;
    display_ampm1();
    		blink_on();
    if(inc==0)
    while(inc==0);
    ahour1++;
    	blink_on();
    if(ahour1>=13)
    ahour1=0;
    else if(dec==0)
    while(!dec);
    ahour1--;
    	blink_on();
    if(ahour1==0)
    ahour1=12;
    if(inc==0)
    while(inc==0);
    amin1++;
    	blink_on();
    if(amin1>=60)
    amin1=0;
    else if(dec==0)
    while(!dec);
    amin1--;
    	blink_on();
    if(amin1==0)
    amin1=60;
    if(inc==0)
    while(inc==0);
    ampm1=0;
    	d=0;
    display_ampm2();
    	blink_on();
    else if(dec==0)
    while(!dec);
    ampm1=1;
    	d=1;
    	display_ampm2();
    	blink_on();
    Lcd8_Command(0x0c);
    cur2--;
    cur2--;
    cur2--;
    cur2--;
    cur2--;
     EEPROM_WriteByte(memo[cur2], ahour);
    cur2++;
     EEPROM_WriteByte(memo[cur2], amin);
    cur2++;
     EEPROM_WriteByte(memo[cur2], ampm);
    cur2++;
     EEPROM_WriteByte(memo[cur2], ahour1);
    cur2++;
     EEPROM_WriteByte(memo[cur2], amin1);
     cur2++;
     EEPROM_WriteByte(memo[cur2], ampm1);
     Lcd8_Command(0x01);
    if(cur2==66)
    	nxt=1;
    void alarm_chk1()
    	for(cur2=1;cur2<25;cur2++)
    		cur2++;
    		cur2++;
    		asec=00;
       if(hour==ahour)
    	 if(min==amin)
       if(sec==asec)
    	 if(clk_ampm==ampm)
    alarm_bell_HI();
    else
    rly=0;
    void alarm_chk2()
    		for(cur2=25;cur2<67;cur2++)
    		cur2++;
    		cur2++;
    		asec=00;
       if(hour==ahour)
    	 if(min==amin)
       if(sec==asec)
    	 if(clk_ampm==ampm)
    alarm_bell_LOW();
    else
    rly=0;
    void alarm_chk3()
    	for(cur4=1;cur4<25;cur4++)
    		cur4++;
    				cur4++;
    		asec=00;
     if(hour==ahour)
    	 if(min==amin)
       if(sec==asec)
    	 if(clk_ampm==ampm)
    alarm_bell_HI();
    else
    rly=0;
    void alarm_chk4()
    		for(cur4=25;cur4<67;cur4++)
    		cur4++;
    						cur4++;
    		asec=00;
     if(hour==ahour)
    	 if(min==amin)
       if(sec==asec)
    	 if(clk_ampm==ampm)
    alarm_bell_LOW();
    else
    rly=0;
    	Lcd8_Command(0x01);
    	Lcd8_Display(0xc0,"Bell ringing.. ",14);
    rly=1;
      delay_ms(12000);
    rly=0;
    	 Delay(65000);
       Delay(65000);
    		 Lcd8_Command(0x01);
    			 Lcd8_Command(0x01);
    rly=1;
    delay_ms(6000);
    rly=0;
    	 Delay(65000);
       Delay(65000);
    		 Lcd8_Command(0x01);
    void Lcd8_Init()
    Lcd8_Command(0x38); //to select function set
    Lcd8_Command(0x06); //entry mode set
    Lcd8_Command(0x0c); //display on
    Lcd8_Command(0x01); //clear display
    void Lcd8_Command(unsigned char com)
    Data_Port=com;
    Lcd_en=1;
    Lcd_rs=0;
    //Lcd_rw=0;
    Delay(125);
    Lcd_en=0;
    Delay(125);
    void Lcd8_Write(unsigned char com,unsigned char lr)
    Lcd8_Command(com);
    Data_Port=lr; // Data
    Lcd_en=Lcd_rs=1;
    //Lcd_rw=0;
    Delay(125);
    Lcd_en=0;
    Delay(125);
    void Lcd8_Display(unsigned char com,const unsigned char *word,unsigned int n)
    unsigned char Lcd_i;
    for(Lcd_i=0;Lcd_i>4); /* Convert to ascii code */
    buf2 = value & 0x0F; /* Filter for low byte */
    buf=(buf1*10)+buf2;
    return buf;
    void Rtc_Init()//lower order 256 bytes of the chip
    Rtc_add_wr=0xd0;
    Rtc_add_rd=0xd1;
    void Rtc_Write(unsigned char zig,unsigned char zag)// program to write to EEPROM
    dat_rtc=zig;
    temp_rtc=zag;
    Rtc_rd_wr_sub();
    above:
    d_rtc=temp_rtc;
    Rtc_Tx();
    if (CY==1)goto above;
    CY=0;
    Rtc_Stop();
    Rtc_Read(unsigned char zig)// program to read from EEPROM
    dat_rtc=zig;
    Rtc_rd_wr_sub();
    Rtc_Start();
    be:
    d_rtc=Rtc_add_rd; // 0xd1 =Rtc_add_rd
    Rtc_Tx();
    if(CY==1)goto be;
    Rtc_Rx();
    Rtc_Ack();
    CY=0;
    Rtc_Stop();
    return(datain_rtc);
    void Rtc_Start()// must for any operation on EEPROM
    sda_rtc=1;
    scl_rtc=1;
    sda_rtc=0;
    scl_rtc=0;
    void Rtc_Stop()// this is similar to the START operation whereas this should be performed after the completion of any operation
    sda_rtc=0;
    scl_rtc=1;
    sda_rtc=1;
    void Rtc_Tx()// program to send the device address, read/write address,data to be written
    signed char i_rtc;
    for(i_rtc=7;i_rtc>=0;i_rtc--)// should necessarily be initialised as signed char.
    CY=(d_rtc>>i_rtc)&0x01;
    sda_rtc=CY;
    scl_rtc=1;// clock is essential inorder to write or read
    scl_rtc=0;// clk should be alternated
    sda_rtc=1;
    scl_rtc=1;
    CY=sda_rtc;
    scl_rtc=0;
    void Rtc_Rx()// program read the data from the EEPROM
    unsigned char l_rtc;
    sda_rtc=1;
    for (l_rtc=0;l_rtc<=7;l_rtc++)
    scl_rtc=1;
    in_rtc=in_rtc<<1;
    in_rtc|=sda_rtc;
    scl_rtc=0;
    datain_rtc=in_rtc;
    in_rtc=0;
    void Rtc_Ack()// this is to intimate the EEPROM that the read operation is over
    sda_rtc=1;
    scl_rtc=1;
    scl_rtc=0;
    void Rtc_rd_wr_sub()// this routine will be used by both the read & write operations to send the device address & the address at which the corresponding action is to be taken
    Rtc_Start();
    here1:
    d_rtc=Rtc_add_wr;// 0xd0 device address is passed
    Rtc_Tx();
    if(CY==1)goto here1;
    again1:
    d_rtc=dat_rtc;// the address from which data is to be read/written is to be passed
    Rtc_Tx();
    if(CY==1)goto again1;
        I2C_Start();               // Start i2c communication
        I2C_Write(EEPROM_ID);      // connect to AT2404 by sending its ID on I2c Bus
        I2C_Ack();
        I2C_Write(eeprom_Address); // Select the Specified EEPROM address of AT2404
        I2C_Ack();
        I2C_Write(eeprom_Data);    // Write the data at specified address
        I2C_Ack();
        I2C_Stop();                // Stop i2c communication after Writing the data
        delay_ms(1);            // Write operation takes max 5ms, refer At2404 datasheet
      unsigned char eeprom_Data;
        I2C_Write(EEPROM_ID);      // connect to AT2404(write) by sending its ID on I2c Bus
        I2C_Ack();
        I2C_Ack();
        I2C_Write(0xA1);           // connect to AT2404(read) by sending its ID on I2c Bus
        I2C_Ack();
       eeprom_Data = I2C_Read();  // Read the data from specified address
        I2C_NoAck();
        I2C_Stop();                // Stop i2c communication after Reading the data
        delay_us(10);
      return eeprom_Data;          // Return the Read data
    void I2C_Start()
        SCL = 0;        // Pull SCL low
        SDA = 1;        // Pull SDA High
        delay_us(1);
        SCL = 1;        //Pull SCL high
        delay_us(1);
        SDA = 0;        //Now Pull SDA LOW, to generate the Start Condition
        delay_us(1);
        SCL = 0;        //Finally Clear the SCL to complete the cycle
    void I2C_Stop(void)
        delay_us(1);
        SDA = 0;            // Pull SDA  low
        delay_us(1);
        SCL = 1;            // Pull SCL High
        delay_us(1);
        SDA = 1;            // Now Pull SDA High, to generate the Stop Condition
    void I2C_Ack()
        SDA = 0;        //Pull SDA low to indicate Positive ACK
        I2C_Clock();    //Generate the Clock
        SDA = 1;        // Pull SDA back to High(IDLE state)
    void I2C_NoAck()
        SDA = 1;        //Pull SDA high to indicate Negative/NO ACK
       I2C_Clock();     // Generate the Clock
        SCL = 1;        // Set SCL */
        unsigned char i;
        for(i=0;i<8;i++)         // loop 8 times to send 1-byte of data
            SDA = dat & 0x80;    // Send Bit by Bit on SDA line
            I2C_Clock();         // Generate Clock at SCL
            dat = dat<<1;
            SDA = 1;                 // Set SDA at last
    unsigned char I2C_Read(void)
        unsigned char i, dat=0x00;
           SDA=1;               //Make SDA as I/P
        for(i=0;i<8;i++)        // loop 8times to read 1-byte of data
           delay_us(1);
            delay_us(1);
            dat = dat<<1;       //dat is Shifted each time and
            dat = dat | SDA;    //ORed with the received bit to pack into byte
            SCL = 0;            // Clear SCL to complete the Clock
       return dat;               // Finally return the received Byte*
            while(ms_count!=0)
                delay_us(112);   //delay_us is called to generate 1ms delay
                 ms_count--;
        while(us_count!=0)
             us_count--;
     void I2C_Clock(void)
        delay_us(1);
        SCL = 1;        // Wait for Some time and Pull the SCL line High
        delay_us(1);        // Wait for Some time
        SCL = 0;        // Pull back the SCL line low to Generate a clock pulse
    video shoot of proteus simulator
    but same problen seen on actual hardware.
    Advanced Member level 2
    Points: 3,130, Level: 13
    baileychic's Avatar
    Aug 2017
    622
    3,130
    13
    Re: Multiplexing problem in my 8051 clock project.
    It is because of using delays in the main loop where the 7 Segment display codes are also called. It is time for you to learn how to multiplex 7 Segment display using Timer interrupt in the interrupt service routine (ISR).
    Points: 24,282, Level: 37
    barry's Avatar
    Mar 2005
    California, USA
    4,656
    24,282
    37
    I’m not about to analyze 5000 lines of code, but it looks like your problem is that it multiplexes the 4 digits properly and then blanks them for a long period. It might be that you’ve got a routine that sends the data to the display which gets called occasionally, then the software goes off and does something else for a long time before it does another display routine.
    Points: 81,430, Level: 69
    2nd Helpful Member
    betwixt's Avatar
    Jul 2009
    Aberdyfi, West Wales, UK
    13,348
    81,430
    69
    I think that should win a prize for the most convoluted and un-commented code ever written to do a simple task.
    When writing a program like that you should first look at the individual tasks it has to perform:
    1. update an LED display
    2. update an LCD display
    3. read an RTC IC
    4. read a keypad
    then prioritize them - only the LED needs constant updating, everything else has latched inputs so use a timer interrupt to keep the multiplexing running at a constant rate.
    Write a routine to do each of those tasks, bearing in mind that the timer ISR will do much of the LED updating.
    I would estimate you could fix the problem and reduce the code down to 25% of its present size if you re-write it that way.
