Results 1 to 4 of 4
    Advanced Member level 2
    Points: 4,214, Level: 15
    Jun 2012
    Chennai
    656
    4,214
    15
    analog pressure gauge to 4 to 20mA
    I have a analog pressure gauge of range 0 to 10bar. Is it possible to provide output of 4 to 20mA. I just want to try it. But don't know how to convert the mechanical to electrical output signal.
    I assume, a magnet can be attached to the pointer shaft of pressure gauge. When the pressure is applied, the magnet on the pointer shaft rotates proportionally to the instrument pointer linearly.
    This can be detected. Am I right? What sensor or IC is to be used?
    Points: 52,905, Level: 56
    Apr 2011
    Minneapolis, Minnesota, USA
    12,942
    52,905
    56
    Re: analog pressure gauge to 4 to 20mA
    A lot depends on the travel distance of the pointer.
    By mounting a tiny strong magnet on it, its position may be detected by a hall sensor. To get linear response needs lots of experimentation and adjustments.
    Optical detection is feasible. Possibly by cutting a paper disc which you glue to the pointer. The disc is painted (or shaped) so it changes light exposure on a photosensor.
    Points: 81,409, Level: 69
    2nd Helpful Member
    betwixt's Avatar
    Jul 2009
    Aberdyfi, West Wales, UK
    13,347
    81,409
    69
    We have no idea what size the pressure gauge is but if we assume it is a standard rotary type with a moving pointer, my approach would be to remove the pointer and replace it with a transparent plastic disc. On the disc I would print (preferably using a laser printer rather than inkjet) a long curved arrow near the outer edge. Then a fixed LED light source and photosensor (an LDR perhaps) would pick up light passing between them but through the arrow. As it rotates, the width of the arrow would obscure more or less light and give you a proportional reading. You still have to convert that to 4-20mA if necessary but that is fairly simple to do electronically.
    If the idea seems practical, you could consider using a different pattern printed on the disc and more sensors to give a direct digital output. You can still convert that to 4-20mA but it becomes more versatile. Research "optical encoders" for ideas and remember laser printing and OHP transparent film is quite cheap these days.
    Points: 14,954, Level: 29
    schmitt trigger's Avatar
    Apr 2013
    2,488
    14,954
    29
    Brilliant suggestion, Brian.
    My batteries are recharged by "Helpful Post" ratings.
