Results 1 to 5 of 5
    Advanced Member level 2
    Points: 2,211, Level: 10
    Aug 2016
    578
    2,211
    10
    Diode performance specification
    Is a fast recovery diodes maximum reverse recovery time the same speed during its max forward current & Repetitive peak reverse voltage or is it much longer than what was specified?
    Points: 11,110, Level: 25
    Aug 2015
    1,808
    11,110
    25
    Re: Diode performance specification
    usually specified on the data sheet, e.g. 125 degC and If = 30A, and dIf/dt = 100A/us ( quite slow ) etc
    you have to read all the fine print carefully...
    Aug 2016
    578
    2,211
    10
    Most small SMT diodes dont have any charts for recovery time or di/dt.
    Points: 24,267, Level: 37
    barry's Avatar
    Mar 2005
    California, USA
    4,654
    24,267
    37
    Quote Originally Posted by Zak28 View Post
    Which is telling you that if those are critical parameters for you, you shouldn’t be using that particular device. It’s like asking what the 0 to 60 acceleration for a Smart Car is. If you’re asking that question, it’s the wrong car. (FYI, it’s double digits).
    Aug 2015
    1,808
    11,110
    25
    if you are using a small diode in a switching ckt and the data sheet does not give switching information, then you use it at your own risk, other batches may differ significantly from the unique one you try in a single prototype.
    For a more guaranteed outcome you have to buy from a manufacturer who does list these parameters, e.g. ST.com
