Results 1 to 5 of 5
    Member level 5
    Points: 1,077, Level: 7
    Jan 2016
    82
    1,077
    7
    Verilog-a code for differential amplifier
    Hello all,
    Here is a simple verilog-a code for an amplifier with differential input and differential output. This works fine with resistors but if i try to use it with switched capacitor circuit, it gives an error
    ERROR (SPECTRE-16384): Signal I(I31.V1:p) = 1.07846 GA exceeds the blowup limit for the quantity `I' which is (1 GA). It is likely that the circuit is unstable.
    Please let me know what modifications needs to be done to correct it.
    module simple_opamp_t(sigin_p, sigin_n, sigout_n, sigout_p);
    input sigin_p, sigin_n;
    output sigout_p, sigout_n;
    electrical sigin_p, sigin_n, sigout_p, sigout_n;
    parameter real gain = 1000000;
    parameter real sigin_offset = 0;
       analog begin
          V(sigout_n) <+ (V(sigin_n) - sigin_offset) * gain;
    	  V(sigout_p) <+ (V(sigin_p) - sigin_offset) * gain;
    end
    endmodule
    Points: 16,998, Level: 31
    pancho_hideboo's Avatar
    Oct 2006
    Real Homeless
    2,612
    16,998
    31
    Re: Verilog-a code for differential amplifier
    What switch do you use in switched capacitor circuit ?
    Is it MOSFET or behavioral ideal switch ?
    Member level 5
    Jan 2016
    82
    1,077
    7
    CMOS switch
    Oct 2006
    Real Homeless
    2,612
    16,998
    31
    Your code is not differential amplifier.
    analog begin
      vdiff = V(sigin_p) - V(sigin_n);
      V(sigout_p) <+ vdiff * gain / 2 + vcom
      V(sigout_n) <+ -vdiff * gain /2 + vcom
    end
    endmodule
    Member level 5
    Jan 2016
    82
    1,077
    7
    Thank you. Shall try this.
