Results 1 to 8 of 8
    Member level 5
    Points: 1,077, Level: 7
    Jan 2016
    82
    1,077
    7
    Verilog-a code to latch analog voltages
    Dear all,
    I am trying to model analog latch in verilog-a but have been unable to do it. The requirement is as follows
    It is required to sample an analog value at positive clock cycle of CLK2 and hold the same value even during the negative clock cycle of CLK2.
    Any leads??
    Points: 16,998, Level: 31
    pancho_hideboo's Avatar
    Oct 2006
    Real Homeless
    2,612
    16,998
    31
    Re: Verilog-a code to latch analog voltages
    Use @cross().
    Member level 5
    Jan 2016
    82
    1,077
    7
    @cross() does not allow V() inside it. Hence it cannot be used
    Oct 2006
    Real Homeless
    2,612
    16,998
    31
    Quote Originally Posted by Chinmaye View Post
    No.
    You can not understand Verilog-A at all.
    if V(clk2) >=0 aho = V(in);
    @cross(V(clk2), -1) aho = V(in);
    V(out) <+ aho;
    Points: 39,705, Level: 48
    Mar 2008
    USA
    6,413
    39,705
    48
    Full Member level 4
    Points: 1,398, Level: 8
    Jan 2019
    Belgium
    199
    1,398
    8
    Dear all,
    Any leads??
    Look at page 113 of http://www.lumerink.com/docs/VerilogA.pdf
    Your exact solution is given!!
  7. #7
    Oct 2006
    Real Homeless
    2,612
    16,998
    31
    Quote Originally Posted by vivekroy View Post
    This is not transparent latch.
    For V(Clk2)=High, V(out)=V(in) ; Tranparent
    Then V(in) is captured at negative edge of V(Clk2).
    V(out) is constant during V(Clk2)=Low ; Hold Mode.
  8. #8
    Full Member level 4
    Jan 2019
    Belgium
    199
    1,398
    8
    Here you go
    // VerilogA code
    `include "constants.vams"
    `include "disciplines.vams"
    module veriloga_latch(vin,vclk,vout_sampled);
    input vin,vclk;
    output vout_sampled;
    voltage vin, vclk, vout_sampled;
    parameter real vdd=1;
    real vsample=0;
    analog begin
    	if (V(vclk)>0.9*vdd) begin
    		vsample=V(vin);
    	end
    	V(vout_sampled) <+ vsample;
    	end
    endmodule
    Here is the op:
