Results 1 to 2 of 2
    Member level 4
    Points: 770, Level: 6
    Apr 2017
    68
    770
    [Moved]Separation of Each bits in 8 bit long(data type) Binary number in mikro c Pro
    Hello All,
    I want to convert long integer to (long)Binary and then separate each bit from my (long data type)Binary number into 8 long variables.
    Not able to get correct output by below code, First tried in C (with Online compiler).
    Please help me!
    Code C - [expand]
    8
    9
    10
    11
    12
    13
    14
    15
    16
    17
    18
    #include <stdio.h>
    void main()
        long num=95,remainder, base = 1, binary = 0;
        while (num > 0)
            remainder = num % 2;
            binary = binary + remainder * base;
            num = num / 2;
            base = base * 10;
        printf("Its binary equivalent is = %ld\n", binary);
        binary >> 7;
        binary & 1;
        printf("New Binary: = %ld\n", binary);
    Last edited by BradtheRad; 11th September 2019 at 06:04. Reason: Added code formatted window
    Junior Member level 1
    Points: 1,117, Level: 7
    Feb 2014
    18
    1,117
    7
    Re: Separation of Each bits in 8 bit long(data type) Binary number in mikro c Pro
    the main difference between int and long int is range only, the number which is not crossed the range of int is same in long also, except while we convert from decimal to binary, we have to add
    zero's at remaining positions.
    ex: int 95 --> 00000000 00000000 00000000 01011111 in binary
    long 95 --> 00000000 00000000 00000000 00000000 00000000 00000000 00000000 01011111 in binary
    Code C - [expand]
    8
    9
    10
    11
    12
    13
    14
    15
    16
    17
    18
    19
    20
    21
    22
    23
    24
    25
    26
    27
    28
    in below code i contains the number of digits in binary representation. then you can add remaining higher bits with zero's like
    : in above code i = 7(no of bits in binary i.e., 1011111)
       binNum[64:7] <= 0;
    // function to convert decimal to binary
    void decToBinary(int n)
        // array to store binary number
        long  binaryNum[64];
        // counter for binary array
        int i = 0;
        while (n > 0) {
            // storing remainder in binary array
            binaryNum[i] = n % 2;
            n = n / 2;
            i++;
        // printing binary array in reverse order
        for (int j = i - 1; j >= 0; j--)
            cout << binaryNum[j];
