Results 1 to 5 of 5
    Newbie level 3
    Points: 171, Level: 2
    Jul 2019
    8
    171
    (ADS) There are no components in ADS after importing my PCB layout from Altium
    I imported my PCB layout from Altium Designer to ADS in ODB++ format as recommended by ADS. The problem is I do not see any of my components in ADS simulation set up. As a result, I cannot change the parameters of the capacitors and etc..
    Nets, substrate and pins are imported but not the components.
    Anyone knows how to solve this?
    Any help is much appreciated.
    Points: 31,659, Level: 43
    BigBoss's Avatar
    Nov 2001
    Turkey
    4,650
    31,659
    43
    Re: (ADS) There are no components in ADS after importing my PCB layout from Altium
    ODBC++ is not a proper way-especially from Altium- to import into ADS.Use simply Gerber format.. no pain..
    Newbie level 3
    Jul 2019
    8
    171
    Ok, I will try importing with gerber format.
    Points: 15,548, Level: 30
    Apr 2014
    2,427
    15,548
    30
    I don't understand why Gerber would be a solution. For sure, there will be no components in Gerber import. Gerber is nothing but polygons. ODB++ has more information that the simple Gerber format.
    But I don't know what to expect for components from ODB++ because ADS would require electrical models - which in my opinion are unknown (not relevant) to Altium. So I'm not surprised that components are missing.
    Newbie level 3
    Jul 2019
    8
    171
    Quote Originally Posted by volker@muehlhaus View Post
    Yes, I tried to import the gerber files and the components are not there as well. (same problem as ODB++)
    Any suggestion on how the layout can be imported to ADS with proper layer stack up, components, nets and pins?
    I am using ADS for SI/PI simulation.
    Thanks in advance.
