Results 1 to 6 of 6
    Member level 3
    Points: 322, Level: 3
    Jul 2019
    66
    322
    Implementation of a MUX for selecting from 2 different sets of inputs
    I have to implement a design in which I have 2 sets of inputs. 1st set consists of different widths of inputs and another set consist of different set of a second input. These two will be selected based on their individual control signals. Is there any way to implement this without having to use two different MUXs? Is there an efficient way in which in can be implemented in one circuit?
    Points: 32,144, Level: 43
    ads-ee's Avatar
    Sep 2013
    USA
    7,437
    32,144
    43
    Re: Implementation of a MUX for selecting from 2 different sets of inputs
    Quote Originally Posted by rrucha View Post
    You really need to learn how to ask a question and describe exactly what you are trying to accomplish. Writing a bunch of vague descriptive text makes it extraordinarily difficult to understand your question.
    What is the first set of inputs? How many and what are the widths?
    What is the second set of inputs? How many and what widths?
    What is the relationship between the first set of inputs and the second set of inputs? Why can't you use simple 2-to-1 multiplexers? What is so special about these inputs?
    What are these individual control signals you mention? Do the control signals multiplex specific pairs of inputs #1 and inputs #2 or is there some other unusual mapping?
    Did you ask this question because you don't want multiple multiplexers? If the circuit requires individual controls to multiplex different pairs of inputs then multiple multiplexers are required by any hardware implementation. Trying to find some clever software approach to the problem isn't the right way to approach designing hardware.
    Well thought out questions shouldn't require this much effort to extract useful information to help.
    Points: 81,147, Level: 69
    Apr 2014
    16,457
    81,147
    69
    I agree with ads-ee.
    I really don't have a clue what you are talking about.
    Draw a sketch of what you want to build and give precise informations and specifications (usually with values and units)
    Member level 3
    Jul 2019
    66
    322
    Sorry. I will try to draw a circuit to explain myself better.
    Last edited by rrucha; 10th September 2019 at 21:30. Reason: not able to explain with words. Will draw an explanation.
    Points: 7,838, Level: 21
    Jul 2010
    Sweden
    1,053
    7,838
    21
    At the lowest level there will be one MUX per output bit, so there is not much to optimize.
    Points: 8,801, Level: 22
    7 years registered Created Blog entry
    dpaul's Avatar
    Jan 2008
    Germany
    1,318
    8,801
    22
    Blog Entries
    Sounds like a stages of MUXes......
    As others have pointed out, a diagram is needed.
