Results 1 to 7 of 7
    Points: 53, Level: 1
    Aug 2019
    53
    What Signal is this?
    Hi guys, is this a low pass?Click image for larger version.
    Points: 81,070, Level: 69
    2nd Helpful Member
    betwixt's Avatar
    Jul 2009
    Aberdyfi, West Wales, UK
    13,292
    81,070
    69
    Re: What Signal is this?
    A rather vague question. If you fed the top waveform into a low pass filter AND it had the right cut-off characteristics AND it had an appropriate load, then yes you could get the lower waveform out.
    There are many other ways it could be produced though.
    Points: 52,666, Level: 56
    Apr 2011
    Minneapolis, Minnesota, USA
    12,895
    52,666
    56
    Yes, you can send the upper waveform through a simple RC or LR circuit, as a low-pass filter, to get the circled waveform.
    Aug 2019
    53
    So it can be a high-pass too, if i send it through a RC circuit?
    Points: 77,136, Level: 67
    Apr 2014
    15,627
    77,136
    67
    Why not looking for the answer on your own?
    Like this: https://lmgtfy.com/?q=square+wave+th...h+pass+picture
    Go throught the results, see the pictures, read through the explanations.
    Points: 259,399, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,290
    259,399
    100
    So it can be a high-pass too.
    No, it can't.
  7. #7
    Junior Member level 1
    Points: 1,117, Level: 7
    Feb 2014
    18
    1,117
    7
    the image given by you not sufficient to tell whether the signal is low pass , high pass, dc or ac or any thing else....
    it depends on the circuit parameters(RC).
    https://www.analog.com/media/en/trai...n/Chapter8.pdf
    just go through above link
