Results 1 to 3 of 3
    Points: 348, Level: 3
    Feb 2019
    46
    348
    Donors , Acceptors and Traps
    How the impurities are different from traps ?
    Also in acceptor impurity, can the electrons from the ionized boron acceptor level jump to Conduction Band at 300 K?
    Feb 2019
    46
    348
    Re: Donors , Acceptors and Traps
    To add it my question, it’s Si doped with Boron. So question is can electrons from acceptor level jump to CB ?
    Points: 39,802, Level: 48
    Mar 2008
    USA
    6,431
    39,802
    48
    Impurities may or may not be trap sites.
    Dopant is desired to be substituted fully into the lattice
    and then it becomes electrically active (in a good way).
    Semiconductor properties are about the lattice, not the
    individual atoms here or there.
    Unsubstituted (interstitial) dopant atoms are a disorder
    and disorder is what gives you the anomalous short
    range order that has differing potential-pockets (traps).
    Other impurities matter as well; high end audio folks
    specify low-oxygen starting material and so on.
    An electron that does "jump to CB" in P-type will be a
    minority carrier and recombine whence it came in short
    order. How short, is doping dependent.
