TRIAC wont conduct, some advice needed
aurelien_7
Newbie level 5
Hi guys,
I am having problem with triac conducting.
In attached schematics triac should control current through R1 by turning potentiometer. I found somewhere on the net schematics and i thought it will work, I dont have to much experience with TRIACs so i would like to hear youw suggestions.
And I am well aware about position of pins regarded to gate terminal, first i thought that maybe i have switched pins but that is probably not the case. I hope it is probably something that i have overlooked:-(
If anything I would expect it conduct most of the time. R2/C1 are a phase shift network to delay the trigger voltage reaching threshold and hence reduce the time current flows but it should conduct more time than less with those values.
If the triac is connected as the schematic symbol tells (G next to A1), A2 to ground, the trigger current must be provided by the capacitor, which probably doesn't work at 24 V.
what do you mean by capacitor doesn't work at 24V?
I thought that maybe it's value is to low so the charge is not sufficient to provide enough current to trigger TRIAC.
Do you perhaps have some suggestion?
220nF @50Hz gives 14.5kOhms.
At 24V RMS sine this gives 1.6mA RMS. Not enough to generate the specified 5mA trigger current.
I still suspect, that the present triac connection isn't intended, usual scheme would connect A1 to ground.
