Results 1 to 6 of 6
    Newbie level 5
    Points: 1,228, Level: 7
    Mar 2013
    8
    1,228
    7
    TRIAC wont conduct, some advice needed
    Hi guys,
    I am having problem with triac conducting.
    In attached schematics triac should control current through R1 by turning potentiometer. I found somewhere on the net schematics and i thought it will work, I dont have to much experience with TRIACs so i would like to hear youw suggestions.
    And I am well aware about position of pins regarded to gate terminal, first i thought that maybe i have switched pins but that is probably not the case. I hope it is probably something that i have overlooked
    Points: 81,426, Level: 69
    2nd Helpful Member
    betwixt's Avatar
    Jul 2009
    Aberdyfi, West Wales, UK
    13,347
    81,426
    69
    Re: TRIAC wont conduct, some advice needed
    If anything I would expect it conduct most of the time. R2/C1 are a phase shift network to delay the trigger voltage reaching threshold and hence reduce the time current flows but it should conduct more time than less with those values.
    Points: 260,224, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,441
    260,224
    100
    If the triac is connected as the schematic symbol tells (G next to A1), A2 to ground, the trigger current must be provided by the capacitor, which probably doesn't work at 24 V.
    Newbie level 5
    Mar 2013
    8
    1,228
    7
    what do you mean by capacitor doesn't work at 24V?
    I thought that maybe it's value is to low so the charge is not sufficient to provide enough current to trigger TRIAC.
    Do you perhaps have some suggestion?
    Points: 77,800, Level: 68
    Apr 2014
    15,764
    77,800
    68
    220nF @50Hz gives 14.5kOhms.
    At 24V RMS sine this gives 1.6mA RMS. Not enough to generate the specified 5mA trigger current.
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,441
    260,224
    100
    I still suspect, that the present triac connection isn't intended, usual scheme would connect A1 to ground.
