INL/DNL Measurement from Cadence Spectre/Virtuoso Output
Puppet123
Full Member level 6
I want to measure the INL/DNL of an ADC designed in Cadence Spectre/Virtuoso.
I understand the methodology: apply an ideal DAC at the output, apply a ramp signal, or a sine wave and get the output and generate a histogram of the output codes.
My question is: how to I generate a histogram of the output codes - that is - a plot of the code vs. the code density (how many times the code appears) in Cadence Spectre/Virtuoso ? Won't it just generate the output What should I make the output look like in Cadence Spectre/Virtuoso - what format - in order to post-process in MATLAB and get the histogram of the output codes ?
Can I use a Verilog-A block in ahdlLib ? Or is their another method ?
Does anyone have a tutorial, reference, paper or thesis that describes this methodology in Cadence Spectre/Virtuoso ?
Thank you.
Ideal DAC is not required.
Both Verilog-A and MATLAB are not required.
Simply do postprocessing of PSF data from Cadence Spectre by Cadence Skill language with Cadence ViVA.
See https://www.edaboard.com/showthread.php?216697
Thank you - can you re-post the hard copy of your setting of "ADE>Tools>Monte Carlo"? They have been removed from the original post.
So, basically, the procedure is:
1. Run a Monte Carlo analysis of the output of the ADC. This way you get a histogram of the code outputs and how often they appear.
2. Post Process the data directly using your Skill Code.
In the newer versions of Cadence Spectre/Virtuoso, there is a histogram function - is that useful ?
Once I get this histogram, how do I measure the DNL/INL ?
Thank you.
Thank you.
So, I use ramp or sine wave drive to determine my output and then use your script to turn it into a histogram in Cadence/Virtuoso?
Then I post-process that histogram plot ?
I think Cadence can generate a histogram plot now, but my question is how to create a plot of codes versus the number of occurrences of that code - in Cadence Spectre/Virtuoso ?
I would use test equipment to do Data Converter measurements but I dont have access to them now, I just have access to EDA tools.
Thank you.
Your answer is nonsense.
In the future, please answer the question being asked.
That's all.
Thank you.
